Thremir
#1 Posted : Monday, April 20, 2015 11:59:28 AM(UTC)
Thremir
Hey!
As time passed by, we really liked the user interface for our ATEM Television Studio which we use together with vMix, and we wanted to make a similar control panel for vMix!
Demonstration Video
Buy it at our webshop!
Cheers,
Håvard
Njastad Webshop
thanks 1 user thanked Thremir for this useful post.
coskel22 on 9/2/2015(UTC)
richardgatarski
#2 Posted : Monday, April 20, 2015 2:17:27 PM(UTC)
richardgatarski
Was thanked: 299 time(s) in 251 post(s)
Well done!
And a nice demo that really prove the points :)
#3 Posted : Monday, April 20, 2015 3:09:47 PM(UTC)
Looks good!
What if you have more than 28 inputs?
Are the buttons configurable to use only the inputs we want, like lower thirds just on the 'overlay' bus etc.?
Or only the first 28 inputs are operational in the order they appear in vMix?
Sondrey
#4 Posted : Monday, April 20, 2015 3:14:45 PM(UTC)
Sondrey
Was thanked: 18 time(s) in 10 post(s)
IceStream wrote:
Looks good!
Hi!
The 28 inputs are the first 28 inputs in vMix, there was another row, but we could not think of a situation where we would use more than 28 inputs :)
We might update it so that if you go over 28, the third row appears.
Thanks for the feedback!
Sondre
Developer @ Shop.njastad.com
#5 Posted : Monday, April 20, 2015 4:08:37 PM(UTC)
@ Thremir & Sondrey
To be honest, I don't think I would "need" access to more than 20 inputs on the actual 'Program' bus,
(I try to limit it to 10 as it is using the Number Keypad 0-9)
but I could easily have in excess of 50 inputs in my set-up, many of which are graphics, lower thirds and/or elements used in compositing FX, so it would be nice to be able configure the 'Control Panel' accordingly.
I typically would not need the 'same' inputs on the 'Overlay' Bus as are on the 'Program' and 'Preview' busses.
That is currently the one thing I do not like about the built-in web interface, every input is there and that is just too many buttons taking up unnecessary space...
Certainly TheCloudMesiaGroup's "vDesk" application for iPad appears to have streamlined the interface, but I am not sure if their product is any more 'configurable' than yours and besides, I don't have an iPad.
As much as I like the convenience and portability of tablets and touch screen options, the biggest downside is the lack of 'tactile' feel, but hey, if it works and is cheaper than a hardware surface, I'll likely go that route first.
Sondrey
#6 Posted : Monday, April 20, 2015 4:13:19 PM(UTC)
Sondrey
Hi!
Would it be a solution for you if you named all your graphics "GFX_[Name]" and then they would show up in the order they appeard in?
Like if you had 4 inputs ->
"GFX_LowerThird" "Video1" "Camera2" "GFX_Logo"
then the overlay row would be;
1 : "GFX_LowerThird" 2 : "GFX_Logo"
This is pretty much the only way i can separate what's GFX and whats ordinary inputs
Sondre
Developer @ shop.njastad.com
#7 Posted : Monday, April 20, 2015 4:34:31 PM(UTC)
If that was the only way to do it, then I would accommodate the practice...
A best case scenario would be by allocating according to vMix 'Category' (colour folders in vMix), that way, all inputs in that category could be placed accordingly.
Sondrey
#8 Posted : Monday, April 20, 2015 4:47:02 PM(UTC)
Sondrey
I will look into it, but i don't think the API provides info about categorizing
Bardos
#9 Posted : Monday, April 20, 2015 10:32:17 PM(UTC)
Bardos
Groups:
IceStream wrote:
Looks good!
I hardly see a setup where more than 15 inputs are used...but in my case with vMix, I put all my video clips in a seperate folder, and add it to vMix as a 'List', and have a hot key to scroll in the 'Preview' window before committing to 'Output'......I do the same with some 'Lower thirds', since I usually make then in 'Fireworks' or 'Photoshop', and use them the same way
#10 Posted : Monday, April 20, 2015 11:56:18 PM(UTC)
@ Bardos
I agree wholeheartedly and in fact I use a lot of those same 'folder' and 'list' practices. As alluded to in my previous posts, I think having 8 to 16 buttons on the 'Program' bus is the most manageable solution (perhaps why the vMixGO Hardware Control Surface and vDesk settled on 12 buttons).
My main concern is being able to configure the controller or at least route the inputs I need to the buttons I want, especially the 'Overlay' bus, which as far as I am concerned could also work as a 'multi-function' bus.
One of my "TESTING" presets has 75 inputs, undoubtedly, they would never all be used in one production, but the point is, the 16 to 20 I would "need" are never the same and certainly wouldn't be a part of the same sequential series of inputs in the preset, whether 12, 20 or in this NjastadCom case 28.
All-in-all though, it's great to see some of these new developments with vMix.
Bardos
#11 Posted : Wednesday, April 22, 2015 5:31:58 PM(UTC)
Bardos
Groups:
What would be nice, is a version where the input buttons are added as I add inputs, the way it is done in Vidblaster, VJDirector2, and similar programs, rather than having all those buttons taking up desktop real estate.....this to me would be a much better design....just adding buttons as the user adds inputs...
waldron18
#12 Posted : Monday, August 31, 2015 7:22:46 AM(UTC)
waldron18
Where abouts can we get access to this? Looks great!
coskel22
#13 Posted : Wednesday, September 2, 2015 6:20:09 PM(UTC)
coskel22
Waldron there is a link to purchase at bottom of OP.
Theremir, looks great and mimics the old-skool hardware nicely.
Bardos
#14 Posted : Wednesday, September 2, 2015 6:40:16 PM(UTC)
Bardos
Groups:
They closed the on line store last week.......is was mentioned in a post.....
waldron18
#15 Posted : Wednesday, September 2, 2015 6:51:47 PM(UTC)
waldron18
Oh no! Just missed it! haha
Any know of another way to purchase it?
Cheers
Sondrey
#16 Posted : Wednesday, September 2, 2015 7:34:02 PM(UTC)
Sondrey
We are in the process of maybe reopening the store. Will get back to yoy guus in the main thread for the store :)
Bandit62
#17 Posted : Friday, August 12, 2016 12:17:18 PM(UTC)
Rank: Guest
Groups:
Whatever happened to this software?.....
Sondrey
#18 Posted : Friday, August 12, 2016 12:19:48 PM(UTC)
Sondrey
The software is in our webshop :)
Guest (8)
