How to Disable "send to Master Audio" for Youtube input
Joined: 9/8/2014(UTC) Posts: 244 Location: Southaven MS
Thanks: 12 times Was thanked: 26 time(s) in 21 post(s)
I am setting up vMix to run the media for our children's church service. I have tried everything and can't get this to work. I have added a Youtube Video as an input doing the following. 1. Add Input > Flash RMTP > https://www.youtube.com/v/qdJicpjitMM2. The video is inserted and I can left mouse click the normal Youtube "play" button to begin playing the video. However, after I cut to the next input I need the audio of the Youtube video to be silenced. I am trying to do either of the following: 1. Add a trigger so that when the Youtube video input is "transitioned out", it will stop sending the audio of that Youtube input to the master audio. I do NOT want to turn the master audio off because the next input that is active will be outputting to the Master Audio. There is a trigger to turn BusA and BusB off, or to turn the Master Audio off, but I could not find the specific trigger to "stop sending a particular input to Master". 2. An alternative option would be to "auto stop the Youtube video". But because this is a Youtube video a left mouse click is the only thing that will pause the video. Does anyone know how to pause a youtube video after transition using triggers? Obviously I can download the video and play it locally but if we need to pull up a video on the fly, I want to be able to insert accomplish my goal above. Thanks for any help. Tim
@ tdurhamjr Unfortunately, vMix does not yet have a 'Flash' Controller to be able to pause or stop animation or playback, although one was developed by AmbotZ a few years ago, so it is possible, just something that was never supported or developed further: http://forums.vmix.com.a....aspx?g=posts&t=1139The Audio is a whole other issue... You may be able to route the audio similar to a 'Skype' set-up, but I am not familiar enough with that to know if it would work or not. Worth looking into though; http://forums.vmix.com.a....aspx?g=posts&t=2518Ice
Thanks Ice! I will look at the audio aspect of it with the link you provided. Maybe Martin will consider adding a feature to help with this. Adding a trigger to "stop sending the audio to master" for a particular input would resolve the problem.
Thanks again Tim
