thecloudmediagroup
#1 Posted : Wednesday, April 15, 2015 7:27:59 PM(UTC)
thecloudmediagroup
Was thanked: 78 time(s) in 43 post(s)
vDesk for iPad is now LIVE in the App Store. Control your vMix session like a broadcast switcher with vDesk!
The link to the app is below. Enjoy!
https://appsto.re/us/Ijvw6.i
Bardos
#2 Posted : Thursday, April 16, 2015 8:34:23 AM(UTC)
Bardos
Groups:
Thanks, but what about the version for PC
thecloudmediagroup
#3 Posted : Saturday, April 18, 2015 2:35:25 PM(UTC)
thecloudmediagroup
The PC version will be a little bit longer. In an effort to make the window resizable, we had to go back and reprogram. What would your normal window size be?
Bardos
#4 Posted : Saturday, April 18, 2015 3:40:07 PM(UTC)
Bardos
Groups:
The version you have, is great...just as it looks in the demo video is great.....maybe just large enough to fit into the area of 2 input rows, as you have it...check the 2 files I uploaded....
Bardos attached the following image(s):
PFBM
#5 Posted : Saturday, April 18, 2015 3:46:31 PM(UTC)
PFBM
HI !
What about android and windows tablets ?
Will it happen ?
Cheers,
PFBM
thecloudmediagroup
#6 Posted : Tuesday, April 21, 2015 1:30:49 PM(UTC)
thecloudmediagroup
PFBM wrote:
HI !
Will it happen ?
Cheers,
PFBM
The Android and Windows versions are essentially done. We are now in the processes of fixing a bug with the function of the T-Bar which has been a difficult process believe it or not. Once the T-Bar function has been fully corrected, the app will then be submitted to the different channels.
-Seth
thanks 1 user thanked thecloudmediagroup for this useful post.
PFBM on 4/21/2015(UTC)
Bardos
#7 Posted : Tuesday, April 21, 2015 3:04:27 PM(UTC)
Bardos
Groups:
Wish there was a timed limit trial version to test drive......30 day or so.....could it be made to add input and other buttons according to the number of inputs, as is done VJDirector and vidblaster.....If I only have 4 inputs, then the control surface only shows 4 buttons, rather than all 12.....This would be great on the desktop real estate
thanks 1 user thanked Bardos for this useful post.
