Joined: 2/27/2013(UTC) Posts: 312   Thanks: 8 times Was thanked: 78 time(s) in 43 post(s)
vDesk for iPad is now LIVE in the App Store. Control your vMix session like a broadcast switcher with vDesk! The link to the app is below. Enjoy! https://appsto.re/us/Ijvw6.i
Groups: Joined: 9/15/2013(UTC) Posts: 168  Location: Barbados Thanks: 14 times Was thanked: 14 time(s) in 13 post(s)
Thanks, but what about the version for PC
Bardos wrote: Thanks, but what about the version for PC The PC version will be a little bit longer. In an effort to make the window resizable, we had to go back and reprogram. What would your normal window size be?
thecloudmediagroup wrote:Bardos wrote: Thanks, but what about the version for PC The PC version will be a little bit longer. In an effort to make the window resizable, we had to go back and reprogram. What would your normal window size be? The version you have, is great...just as it looks in the demo video is great.....maybe just large enough to fit into the area of 2 input rows, as you have it...check the 2 files I uploaded.... Bardos attached the following image(s):  vMix%20A.png (1,828kb) downloaded 21 time(s). vMix.png (1,722kb) downloaded 10 time(s).You cannot view/download attachments. Try to login or register.
Joined: 3/30/2011(UTC) Posts: 311  Location: Portugal Thanks: 360 times Was thanked: 37 time(s) in 31 post(s)
HI !
What about android and windows tablets ?
Will it happen ?
Cheers,
PFBM
PFBM wrote:HI !
Will it happen ?
Cheers,
PFBM The Android and Windows versions are essentially done. We are now in the processes of fixing a bug with the function of the T-Bar which has been a difficult process believe it or not. Once the T-Bar function has been fully corrected, the app will then be submitted to the different channels. -Seth
 1 user thanked thecloudmediagroup for this useful post.
Wish there was a timed limit trial version to test drive......30 day or so.....could it be made to add input and other buttons according to the number of inputs, as is done VJDirector and vidblaster.....If I only have 4 inputs, then the control surface only shows 4 buttons, rather than all 12.....This would be great on the desktop real estate
 1 user thanked Bardos for this useful post.
