Hardware Compatibility
Need advice on this PC system please for Vmix pro
I looking a putting a system together and I'm wondering if this PC would be suitable.
I have been a Mac user for well over a decade and have no Idea on a PC system.
From info I found on these forums I think this setup should work?
Cameras will be Broadcast Sony Cameras, Sony PMW500 outputting via SDI: XDCAM HD (MPEG-2 4:2:2 @50Mbps)
Matrox Quad HD Streaming/Capture Card VS4 NVIDIA Quadro K600 with 1GB Memory System Drive: 1 x 7200 RPM SATA II Storage Drive: 2 x 720 RPM Sata II drives in a striped RAID array
I was looking at putting this in a HP Z230 SFF Workstation Intel® Core™ i7-4770 with Intel® HD Graphics 4600 (3.4 GHz, 8 MB cache, 4 cores) 8 GB 1600 MHz DDR3 non-ECC Unbuffered RAM (2 x 4 GB)
I would change the 8GB ran to 16GB.
I would also be running the Vmix pro version as I need the 4 x replay function.
Can anyone confirm that this setup would work please.
Cheers
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
Thanks IceStream,
The graphic card I was thinking was the NVIDIA Quadro K600 with 1GB Memory. The NVIDIA 960 2GB is recommended here on this site, I'll go with that.
