asxnot
#1 Posted : Saturday, February 25, 2012 2:53:50 AM(UTC)
asxnot
Hello!
I installed the vMix Trial Version and... what an amazing software!!
Anyway I have a problem while opening powerpoint and mov videos. I installed both Powerpoint and QuickTime but with ppt files I get a "Cannot create ActiveX component" and with mov files "QuickTime 7.6 or higher is not installed".
What am I doing wrong? May it depends on the OS (Windows 7 Home Premium in Italian)?
Manuel
#2 Posted : Saturday, February 25, 2012 5:24:23 AM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
PowerPoint 2007 or higher is required. If installing PowerPoint 2010 make sure it is the 32bit version.
For QuickTime, it will require a computer reboot before it will work.
asxnot
#3 Posted : Sunday, February 26, 2012 3:53:51 AM(UTC)
asxnot
Hi Martin,
thank you very much for your answer. Actually after the reboot, mov files can be opened.
Unfortunatelly my PowerPoint 2010 32 bit (I have Office 2010 Home & Student preinstalled on my pc) still doesn't work. I tried both with ppt and pptx files: the message is always the same.
Since I don't know Active X world, I have no clues on what the problem may be.
Manuel
#4 Posted : Sunday, February 26, 2012 5:36:49 AM(UTC)
See if this helps:
http://office.microsoft....5&origin=HA101850565
