illpicasso
#1 Posted : Tuesday, February 11, 2014 3:09:45 PM(UTC)
illpicasso
Is or will this i/o be compatible with vmix? Any testing planned.
http://www.aja.com/en/products/io-4k
ericn
#2 Posted : Friday, March 27, 2015 6:42:54 PM(UTC)
ericn
It works now and is supported as of vMIx 14!
j1mco
#3 Posted : Friday, April 3, 2015 10:44:16 AM(UTC)
j1mco
Yep - we just bought one.
Seems you can't run HDMI simultaneously to SDI inputs.
But 4 SDI works fine...
thomas
#4 Posted : Friday, April 3, 2015 11:26:20 AM(UTC)
thomas
I think you can. The HDMI-input is the same as SDI-1, I have read. Let me know if it does not work, since I am curious about how well Aja IO 4K works with vMix..
Btw, can you use four SDI-input and use external out from vMix to the aja 4K SDI-out?
j1mco
#5 Posted : Friday, April 3, 2015 12:12:03 PM(UTC)
j1mco
We did set HDMI as the input 1 and cameras to the other 3. The HDMI input was a 1080p60 feed from a PC. However, this seemed to disable all other SDI inputs in vmix, and reported "in use" when we tried to add the inputs.
The HDMI, despite being a 1080p60 feed showed in control panel that it was UHD (i guess taking up all bandwidth for the other SDI channels).
We'll try again, but we definitely couldn't get it working the first time we tried.
We'll try the output too and report back - but according to specification, I don't think this will work... it's all very vague!
thanks 1 user thanked j1mco for this useful post.
thomas on 4/3/2015(UTC)
thomas
#6 Posted : Friday, April 3, 2015 12:17:01 PM(UTC)
thomas
Can you i.e have three inputs and one output? I am considering the Aja IO 4K. But it`s meant to be used for broadcast purpose, and having an output from vMix is a must..
#7 Posted : Saturday, April 4, 2015 3:54:15 AM(UTC)
Was thanked: 4739 time(s) in 1626 post(s)
Hi Guys,
The Io 4K is extremely flexible in the way the inputs and outputs can be used.
I hope the following points help clarify a few things:
* The Io 4K has 4 HD channels available (1,2,3 and 4), these are all combined together when using 4K (UHD) sources.
* HDMI output can be used with channel 1 only
* Either channel 1 or channel 2 can be used for HDMI input
* When using HDMI from a PC, you may need to reboot the Io4K after changing screen resolution
* Make sure the latest version of vMix 15 is installed and also the latest Io4K drivers from the AJA web site.
* 3 inputs and 1 output is possible. With vMix 4K and Pro you can run it with 2 inputs and 2 outputs if needed.
thomas on 4/4/2015(UTC), ericn on 4/7/2015(UTC)
epicenter800
#8 Posted : Tuesday, April 21, 2015 11:06:46 AM(UTC)
epicenter800
I am currently using one 4K IO with a Thunderbolt 2 equipped laptop. Moving forward, I'd like to ingest 5 robocams with 720/59.94 outputs and maybe a PC for graphics. At the same, I'd like to output to a projector and a recorder, making a total of 6 inputs and 2 outputs. With the cameras taking about 1.5 gbps each and the outputs the same, would two 4 IO's work (considering the approximate total of 14 gbps and Thunderbolt 2's 20gbps bandwidth limitation)? Also, with that many inputs, should I now be worried about taxing my CPU or is the ingestion all GPU processed (I have a 6gb GPU installed).
Thanks!
