melody
#1 Posted : Monday, February 13, 2012 10:01:05 PM(UTC)
Rank: Guest
Groups: Guests
hi martin,
here goes the situations:
1. i find some drops on recording and flash encoder every time i need to use vmix in background, to see something in the computer;
2. using my cameras in hdv (pal 50fps) there`s some constant 4-7 drops. same drops using LAV to render hdv at 25fps;
what can i to have better results?
desktop settings:
cpu - intel i7 920
gpu - ati radeon hd 5750 1go DDR5
ram - 12go triple channel
motherboard - asus p6t
regards,
melody
www.espiritosanto.cc
#2 Posted : Wednesday, February 15, 2012 2:13:35 AM(UTC)
HDV is not recommended due to the many different MPEG-2 codecs available and the reliability problems that introduces.
(DV should be fine in comparison)
If you must use HDV, try using a different MPEG-2 decoder, particularly one that displays the cameras at 25fps rather than 50fps.
I can't offer any recommendations for codecs unfortunately.
I always recommend getting DeckLink/Intensity cards as these ensure the best performance and least dropped frames.
To stop other programs taking the vMix resources, in Settings -> Performance set Application Priority to Above Normal.
melody
#3 Posted : Wednesday, February 15, 2012 6:40:51 AM(UTC)
Rank: Guest
Groups: Guests
hi,
at once, the "best" mpeg2 render i used was LAV, some fine settings, good performance and possibility to choose behind 25fps or 50fps but i think the problem is not exactly the framerate, the problem i have here is the constant 4-7 drops on both framerate.
i noticed too that "synchronize output with refresh rate" picked option interferes with hdv sources, them works at 30fps max when 50fps is selected.
thank you for your reply, regards,
melody
#4 Posted : Wednesday, February 15, 2012 12:01:11 PM(UTC)
LAV will interfere as it uses CUDA acceleration which will compete with vMix for graphics card resources.
Please choose a decoder that is not hardware accelerated and runs at 25fps and untick synchronize output with refresh rate as it is only for XP.
melody
#5 Posted : Wednesday, February 15, 2012 1:08:13 PM(UTC)
Rank: Guest
Groups: Guests
thats ok, i`ll try another decoder. however i`m using windows 7 x64
edit: i founded this article with a "battle comparison" of diferente mpeg2 encoders/decoders/renders... maybe its interesting for you martin to implement a part of the "Intel® Integrated Performance Primitives" code on vmix.
http://compression.ru/vi..._comparison_2006_eng.pdf
