halfpipe
#1 Posted : Wednesday, February 8, 2012 4:31:04 PM(UTC)
halfpipe
The dialoue box below is what I get when attempting to add a firewire camera to the vmix which has a shuttle hdmi input The program sees the specific camera in the Input select capture dialogue however the dreaded blue box appears
"vMix2012
AddNewInput
The supplied user buffer is not valid for the requested operation."
Are basic tutorials or walk thrus on Youtube or elsewhere please?
Bruce
firewire is not an option in the list
#2 Posted : Thursday, February 9, 2012 12:24:00 AM(UTC)
Was thanked: 4729 time(s) in 1621 post(s)
Could you please send an error report so I can investigate further?
Thanks,
#3 Posted : Thursday, February 9, 2012 11:22:48 AM(UTC)
I've looked at the error message and it looks like it might be a firewire card issue so you might need to try another card.
halfpipe
#4 Posted : Thursday, February 9, 2012 12:26:13 PM(UTC)
halfpipe
thanks ..another point is that this camera produces a 1440x1080 hdv signal which is not listed within the selectable resolutions dialogue.
When the camera is set to downconvert and in DV output mode, the input is accepted albeit without audio
#5 Posted : Thursday, February 9, 2012 9:00:05 PM(UTC)
The Resolution, Input and System boxes are not used for DV/HDV so it doesn't matter what they are set to.
halfpipe
#6 Posted : Thursday, February 9, 2012 9:44:24 PM(UTC)
halfpipe
It seems 64bit Win7 is quite unfriendly to firewire this according to umpteen forums I've googled on the topic
I best forget those HDV cams in the bottom drawerr and get an Intensity pro to go with the intensity shuttle and take it from there
Luc Henrion
#7 Posted : Friday, February 10, 2012 3:40:35 AM(UTC)
Luc Henrion
I might be wrong, but I think that Firewire, when used as a video input, is limited to SD resolution...
mironhtu
#8 Posted : Monday, February 20, 2012 12:37:01 AM(UTC)
mironhtu
You are wrong. You can do HDV thru Firewire, which is kind of HD (1440 x 1080).
