Bardos
#1 Posted : Tuesday, March 3, 2015 10:02:11 AM(UTC)
Bardos
Groups:
I am having a problem with my shortcuts in ver 14...06....I can not get my list to work...I tried all the keys as short cuts, and none is working.....what am I doing wrong.....This is in the custom section....I want to use the forward arrow to advance to clips in the Play List, but nothing seems to work ...
need help here
tdurhamjr
#2 Posted : Tuesday, March 3, 2015 11:42:19 AM(UTC)
tdurhamjr
Was thanked: 26 time(s) in 21 post(s)
Bardos,
I don't fully understand your question. Are you trying to create shortcuts using SETTINGS > SHORTCUTS or some other method?
Tim
Bardos
#3 Posted : Wednesday, March 4, 2015 3:35:52 PM(UTC)
Bardos
Groups:
I am using Settings> Shortcuts> Add>......when I add the key, and function, it does NOT work for List.....The items in the List suppose to change when I use the key I select for the change...it does NOT work
UPDATE:...Out of determination I went back into the Settings, and found the listing 'Next Item'...tried it, and now it works...'Next Item in Play List' did not work...
Similar Topics
API to edit Shortcuts and Activators (Feature Requests)
by thereis 10/17/2026 3:14:21 AM(UTC)
Shortcuts Enabling/Disabling Multicord Sources (Feature Requests)
by Alex Stearns 6/3/2026 1:31:24 AM(UTC)
Production Clock Shortcuts (Feature Requests)
by Alex Stearns 6/3/2026 1:24:28 AM(UTC)
Shortcuts - Dropdown menu for Script selection (Feature Requests)
by mikesg 4/8/2026 3:50:45 AM(UTC)
Shortcuts for X-Keys (Hardware Compatibility)
by WRONBA 3/12/2026 10:50:42 PM(UTC)
Replay API + Request for new shortcuts (Feature Requests)
by aircooled76@gmail.com 2/1/2026 5:50:22 PM(UTC)
How to increase / decrease audio volume step by step using keyboard shortcuts in vMix 29? (General Discussion)
by medesan 1/15/2026 5:45:35 AM(UTC)
Lost all my shortcuts (General Discussion)
by SpaceAge 9/9/2025 9:26:48 AM(UTC)
Suggestion vMix Replay v29 NewShortcuts (Feature Requests)
by InstantReplayGO 8/19/2025 5:57:14 AM(UTC)
Thank for new vMix Replay Shortcuts v29 (Beta Discussion)
by InstantReplayGO 8/17/2025 12:02:44 PM(UTC)
"Set Stinger" Shortcuts not working (General Discussion)
by knbPixels 5/2/2025 11:30:11 AM(UTC)
Overlay Shortcuts (General Discussion)
by Cyberkorr 4/27/2025 7:36:36 AM(UTC)
Add new vMix Replay shortcuts (Feature Requests)
by InstantReplayGO 4/26/2025 3:12:21 AM(UTC)
merge presets including their local shortcuts/activators (Feature Requests)
by mjehnichen 2/13/2025 9:58:29 AM(UTC)
telestrator shortcuts (General Discussion)
by jane 1/31/2025 4:17:51 AM(UTC)
Feature Request: Folders in shortcuts, activators and Scripts (Feature Requests)
by Harm VE 1/25/2025 11:54:45 PM(UTC)
Merging Scripts and Shortcuts (only) (General Discussion)
by vjmandala 12/3/2024 3:04:04 PM(UTC)
Web Controller - shortcuts (Feature Requests)
by vjmandala 11/27/2024 9:02:41 AM(UTC)
Multiple Shortcuts in one press (Feature Requests)
by vjmandala 11/27/2024 8:59:38 AM(UTC)
overlay channels shortcuts-same input between mix inputs (Beta Discussion)
by nikosman88 11/22/2024 11:41:33 PM(UTC)
Shortcuts for Midi to control of all/any sliders (Feature Requests)
by vjmandala 11/14/2024 11:46:06 AM(UTC)
VMix shortcuts - sliders (General Discussion)
by vjmandala 11/13/2024 2:24:15 PM(UTC)
Add Split Audio Controls via Shortcuts along with Mono Sum (Feature Requests)
by offroadmediagroup 11/6/2024 3:49:33 AM(UTC)
"Shortcuts only" sringers/overlays on sub mixes (General Discussion)
by spinfold 10/12/2024 10:25:38 PM(UTC)
Identify or sort shortcuts by shortkey (Feature Requests)
by Salleman 10/2/2024 7:00:01 PM(UTC)
Streamdeck Shortcuts disappeared (General Discussion)
by Johann973 9/30/2024 9:35:41 AM(UTC)
Shortcuts to change output multiview slots (Feature Requests)
by WaltG12 9/21/2024 5:17:00 AM(UTC)
Channel Mixer shortcuts (General Discussion)
by mark 8/31/2024 12:25:31 PM(UTC)
VMix call remote shortcuts (Feature Requests)
by DJShaggyd 8/20/2024 9:42:55 PM(UTC)
Shortcuts to adjust Text Font Size (e.g. for use as a teleprompter) (Feature Requests)
by richardgatarski 7/19/2024 6:40:57 AM(UTC)
