Instant Replay
Matrox MXO2 Mini capture device and Instant Replay
Joined: 6/2/2012(UTC) Posts: 103  Location: Germany Thanks: 13 times Was thanked: 10 time(s) in 9 post(s)
I have a Matrox MXO2 Mini capture device and a camera connected via HDMI input. If I select this input as an Instant Replay camera, I got an error "Matrox A/V Input video format must be YUV. Source is reporting format RGB32 32 22". I couldn't find a way to change it to YUV.
Joined: 1/13/2010(UTC) Posts: 5,358  Location: Gold Coast, Australia Was thanked: 4765 time(s) in 1636 post(s)
Check to see if the latest drivers are installed for the MXO2. I don't have one here to test but I know the Matrox VS4 supports YUV formats, so I assumed it would be the same.
Maybe my camcorder Panasonic HC-V707 supports only the colorspace RGB. Is there a way to convert it to YUV?
The Matrox device supports both: MXO2 video connections • One HD HDMI input and one HD/SD HDMI output, both with up to eight channels of embedded audio support. The HDMI input/output supports YUV and RGB devices
Instant Replay
