cutter07
#1 Posted : Sunday, February 22, 2015 9:20:02 AM(UTC)
cutter07
I have a Matrox MXO2 Mini capture device and a camera connected via HDMI input. If I select this input as an Instant Replay camera, I got an error "Matrox A/V Input video format must be YUV. Source is reporting format RGB32 32 22".
I couldn't find a way to change it to YUV.
#2 Posted : Sunday, February 22, 2015 9:25:15 AM(UTC)
Check to see if the latest drivers are installed for the MXO2.
I don't have one here to test but I know the Matrox VS4 supports YUV formats, so I assumed it would be the same.
cutter07
#3 Posted : Sunday, February 22, 2015 10:54:49 AM(UTC)
cutter07
Maybe my camcorder Panasonic HC-V707 supports only the colorspace RGB.
Is there a way to convert it to YUV?
The Matrox device supports both:
MXO2 video connections
• One HD HDMI input and one HD/SD HDMI output, both with up to eight
channels of embedded audio support. The HDMI input/output supports YUV
and RGB devices
