Innomedia
#1 Posted : Wednesday, February 11, 2015 9:39:58 AM(UTC)
Innomedia
Was thanked: 19 time(s) in 10 post(s)
Last weekend we were testing new instant replay system at our hockey rink while kids are playing a tournament. We also used Contour ShuttlePro USB-Controller and it was really fun using this exciting new version 15.0.0.40 on our 4-channel workstation. Standard was 4 cameras with 720p50 and everything was fine except pressing a shortcut button on ShuttlePro Controller to create a new highlight. VMIX added 4 identical clips to the replay list (all of them had 4 angles), so we had to remove 3 of these clips each time we wanted to mark a highlight. It did not happen in first beta and in version 15.0.0.35 so were very surprised about this "new feature" which seems to be a bug.
Regards
Karsten
#2 Posted : Wednesday, February 11, 2015 12:47:36 PM(UTC)
Was thanked: 4714 time(s) in 1616 post(s)
Hi Karsten,
What function and settings were used for the shortcut?
krassesPferd
#3 Posted : Wednesday, February 11, 2015 1:03:53 PM(UTC)
krassesPferd
Was thanked: 8 time(s) in 7 post(s)
I have the same problem. I use "ReplayMarkInOut" as function and "10" as value. In 15.0.0.35 it worked this way. Now I always get this highlight 4 times into eventlist 1 when using the m-button on my shuttlepro v2. When I use the "-10" button on the GUI the highlight only appears one time.
Yannick
Innomedia
#4 Posted : Wednesday, February 11, 2015 3:00:49 PM(UTC)
Innomedia
admin wrote:
Hi Karsten,
We used "ReplayMarkInOut" for this shortcut (I guess it was attached to ReplayK on the Shuttle), value was 10 or 12. We tried a lot during last week so I do not exactly remember the particular values. We did not register this effect in the versions before.
Regards
Karsten
#5 Posted : Saturday, February 14, 2015 5:09:58 AM(UTC)
I've been doing some testing and can't seem to recreate this issue.
It sounds like maybe there are multiple shortcuts for the same key or maybe a conflict with the ShuttlePRO software if it is installed.
Does it happen consistently or only in some situations?
As a test, try uninstalling the ShuttlePro software as vMix does not need it to work.
PFBM on 8/15/2015(UTC)
