Instant Replay
Multiple clips by using shortcut
Joined: 11/8/2013(UTC) Posts: 87  Location: Bavaria, Germany Thanks: 6 times Was thanked: 19 time(s) in 10 post(s)
Last weekend we were testing new instant replay system at our hockey rink while kids are playing a tournament. We also used Contour ShuttlePro USB-Controller and it was really fun using this exciting new version 15.0.0.40 on our 4-channel workstation. Standard was 4 cameras with 720p50 and everything was fine except pressing a shortcut button on ShuttlePro Controller to create a new highlight. VMIX added 4 identical clips to the replay list (all of them had 4 angles), so we had to remove 3 of these clips each time we wanted to mark a highlight. It did not happen in first beta and in version 15.0.0.35 so were very surprised about this "new feature" which seems to be a bug.
Regards Karsten
Joined: 1/13/2010(UTC) Posts: 5,375  Location: Gold Coast, Australia Was thanked: 4801 time(s) in 1648 post(s)
Hi Karsten,
What function and settings were used for the shortcut?
Thanks: 8 times Was thanked: 8 time(s) in 7 post(s)
I have the same problem. I use "ReplayMarkInOut" as function and "10" as value. In 15.0.0.35 it worked this way. Now I always get this highlight 4 times into eventlist 1 when using the m-button on my shuttlepro v2. When I use the "-10" button on the GUI the highlight only appears one time. Regards, Yannick
admin wrote:Hi Karsten,
Martin We used "ReplayMarkInOut" for this shortcut (I guess it was attached to ReplayK on the Shuttle), value was 10 or 12. We tried a lot during last week so I do not exactly remember the particular values. We did not register this effect in the versions before. Regards Karsten
I've been doing some testing and can't seem to recreate this issue. It sounds like maybe there are multiple shortcuts for the same key or maybe a conflict with the ShuttlePRO software if it is installed.
Does it happen consistently or only in some situations?
As a test, try uninstalling the ShuttlePro software as vMix does not need it to work.
Martin vMix
Instant Replay
