Hi Recently bought vmix after testing both this solution and wirecast. Now i have 1 major problem, with the quality of the remote capture, it's impossible to se details in a powerpoint, for example smaller numbers in a table. When testing on the same machine but with wirecast (out of the box settings), I get remarkable better quality, and even with the file size going from 100mb to around 4mb Any suggestions on how i can get a acceptable quaility with vmix? Vmix screen capture:  Wirecast screen capture:  Vmix recording setup:
Joined: 1/13/2010(UTC) Posts: 5,346  Location: Gold Coast, Australia Was thanked: 4749 time(s) in 1632 post(s)
Looks like the Output Size in vMix Settings is set too low. You will need to set this to 1280x720 to match the recording.
Martin vMix
Thanks Martin, that fixed the problem :)
