Staxen
#1 Posted : Friday, February 6, 2015 7:57:20 AM(UTC)
Staxen
Hi
Recently bought vmix after testing both this solution and wirecast.
Now i have 1 major problem, with the quality of the remote capture, it's impossible to se details in a powerpoint, for example smaller numbers in a table.
When testing on the same machine but with wirecast (out of the box settings), I get remarkable better quality, and even with the file size going from 100mb to around 4mb
Any suggestions on how i can get a acceptable quaility with vmix?
Vmix screen capture:
Wirecast screen capture:
Vmix recording setup:
#2 Posted : Friday, February 6, 2015 8:35:53 AM(UTC)
Was thanked: 4750 time(s) in 1632 post(s)
Looks like the Output Size in vMix Settings is set too low.
You will need to set this to 1280x720 to match the recording.
Staxen
#3 Posted : Monday, February 9, 2015 3:58:37 AM(UTC)
Staxen
Thanks Martin, that fixed the problem :)
