Ittaidv
#1 Posted : Thursday, February 5, 2015 1:06:31 PM(UTC)
Ittaidv
Is there a way to seperate the internet connections, so I can stream over ethernet cable, while using tally over wifi?
#2 Posted : Thursday, February 5, 2015 1:38:29 PM(UTC)
I have done screencapture remote pc on local wifi network while streaming through wired internet (seperate network) for example if that helps
Ittaidv on 2/7/2015(UTC)
ask
#3 Posted : Thursday, February 5, 2015 4:53:02 PM(UTC)
ask
You need to configure this in windows. Have a read here: http://windows.microsoft...teways#1TC=windows-vista
tesn
#4 Posted : Monday, December 19, 2016 9:55:28 AM(UTC)
tesn
Was thanked: 13 time(s) in 9 post(s)
I sort of have this question myself. Trying to wrap my head around it.
For our next event, I'm fairly certain we're going to have a dedicated hard line run for our streaming. I suspect the venue's wifi will be on a separate network.
Our streaming machine has ethernet and wifi. How do we set it up such that vMix streams on the hard line, but uses the wifi for the webcontroller/tally? I can't quite picture it.
Has anyone done this?
-Brian
Cpilcher
#5 Posted : Monday, December 19, 2016 10:52:30 AM(UTC)
Cpilcher
I do this. I have a dual Ethernet port motherboard and use one port for Ethernet connection to network and the other for my connection to a wifi router. Works well for me.
Chuck
Just to clarify: The WiFi router has no internet connection it is just used to communicate with my devices for Tally and webcontroller. I can pull up my notes on my specific settings if you have trouble getting it working but it is fairly simple if you have 2 seperate ports.
xaver
#6 Posted : Monday, December 19, 2016 11:09:37 AM(UTC)
xaver
that works if you have two ethernet conenction on different networks
one (for streaming) with gateway
the other (wifi / remote) without gateway
tesn
#7 Posted : Tuesday, December 20, 2016 12:22:28 PM(UTC)
tesn
Ok . . . yeah. I was sort of coming to the conclusion that we'd provide our own wifi router. Our pc actually does have dual ethernet ports and wifi. We have a switch that we typically use to split our dedicated line. I guess we can just plug in our own wifi there as well.
Only have one camera that we're going to put a tally on. Thinking an old iPod touch will do the trick.
Thanks,
-Brian
