Instant Replay
Can vMix 14 and 15 peacefully coexist?
Joined: 2/9/2013(UTC) Posts: 265 Location: Katy, Texas
Is it possible to have both vMix 14.112 and vMix 15.32 installed on the same machine at the same time? My production machine has more robust hardware that is closer to the requirements of vMix 15, but I'm afraid to install it unless the 2 versions can coexist on the same machine.
Thoughts?
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
That is possible, just choose another install folder for the second version.
If you want to uninstall the first installed version then run uninst000.exe from the first version folder.
Joined: 8/5/2013(UTC) Posts: 280  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
wwdv wrote:That is possible, just choose another install folder for the second version.
If you want to uninstall the first installed version then run uninst000.exe from the first version folder. Did you try it (installing, using, uninstalling two vmix version) or you thoughts are in theory? Could admin clarify this? I'm a little worried if 2 vmix'es don't share some libraries That can be changed by one of installation and make influance on working 2nd installation.
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
I do this all the time , new version in different folder, haven't noticed any issues so far
r@wisla wrote: Did you try it (installing, using, uninstalling two vmix version) or you thoughts are in theory?
Yes, I tested it. You can even run them at the same time, but you can't use inputs simultaneously.
Instant Replay
