Kelvin
#1 Posted : Thursday, January 29, 2015 8:54:39 PM(UTC)
Kelvin
Is it possible to have both vMix 14.112 and vMix 15.32 installed on the same machine at the same time? My production machine has more robust hardware that is closer to the requirements of vMix 15, but I'm afraid to install it unless the 2 versions can coexist on the same machine.
Thoughts?
wwdv
#2 Posted : Thursday, February 5, 2015 8:52:03 AM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
That is possible, just choose another install folder for the second version.
If you want to uninstall the first installed version then run uninst000.exe from the first version folder.
r@wisla
#3 Posted : Friday, February 6, 2015 4:09:45 AM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
Did you try it (installing, using, uninstalling two vmix version) or you thoughts are in theory?
Could admin clarify this? I'm a little worried if 2 vmix'es don't share some libraries That can be changed by one of installation and make influance on working 2nd installation.
#4 Posted : Friday, February 6, 2015 4:36:02 AM(UTC)
I do this all the time , new version in different folder, haven't noticed any issues so far
r@wisla on 2/6/2015(UTC)
wwdv
#5 Posted : Friday, February 6, 2015 3:02:51 PM(UTC)
wwdv
Yes, I tested it.
You can even run them at the same time, but you can't use inputs simultaneously.
