StreamingStijn
#1 Posted : Thursday, January 15, 2015 11:57:27 AM(UTC)
StreamingStijn
I'm using vmix to create a virtual webcam input from an IP cam (rtsp url) and pick it up with Flash Live Media Encoder to stream on youtube.
By adding a stream input and then click stream it would create an image in fmle so I had it working.
But now after doing nothing with it for a few weeks (not even using the computer) It stopped working.
If I add the rtsp url every 10 seconds it loses connection and gives me an error saying "error rtsp not responding".
What is causing this problem?
Thank you in advance.
(if I forgot any information feel free to ask. I will check this forum regularly)
tnorrell
#2 Posted : Monday, January 26, 2015 11:10:40 PM(UTC)
tnorrell
Was thanked: 13 time(s) in 10 post(s)
Most likely, something has happened/changed on your network. If I were you, I would do a package capture at the switch between the cam and vmix and see what data is being sent. What IP Cam are you using?
