I'm using vmix to create a virtual webcam input from an IP cam (rtsp url) and pick it up with Flash Live Media Encoder to stream on youtube. By adding a stream input and then click stream it would create an image in fmle so I had it working. But now after doing nothing with it for a few weeks (not even using the computer) It stopped working. If I add the rtsp url every 10 seconds it loses connection and gives me an error saying "error rtsp not responding". What is causing this problem?
Thank you in advance.
(if I forgot any information feel free to ask. I will check this forum regularly)
Thanks: 22 times Was thanked: 13 time(s) in 10 post(s)
Most likely, something has happened/changed on your network. If I were you, I would do a package capture at the switch between the cam and vmix and see what data is being sent. What IP Cam are you using?
