luthierwnc
#1 Posted : Wednesday, January 14, 2015 1:01:10 PM(UTC)
luthierwnc
Hi All,
I am new to this and can't find a guide on how to cut and paste videos. I shot a podcast and reshot the ending. All I need to do now is put the new ending in place of the original. I have both of the vids on the screen and played with the fade control but I don't know how to add one to the other or how to save the working project.
Any ideas? Thanks, sh
Win7 64-bit
i5 processor 8 GB RAM
recorded in MPEG
VMIX Basic HD
richardgatarski
#2 Posted : Wednesday, January 14, 2015 1:20:24 PM(UTC)
richardgatarski
Well, vMix is not the best solution for that.
In theory you could:
- load your two recordings into two different video inputs
- cue each one to where you want to start playing
- click "Cut" on the first video to get it into Output
- Start recorder and immediately start plaing the first video
- when first video ends, cut/fade to the second video and play it
- when second video ends, stop recording
(some of the above could be automated with shortcuts and autostarts)
But you would be much better of with any video editor - lots of free ones. Or a dedicated video splitter, such as http://applian.com/replay-media-splitter/
Good luck!
luthierwnc on 1/14/2015(UTC)
luthierwnc
#3 Posted : Wednesday, January 14, 2015 1:58:24 PM(UTC)
luthierwnc
Thanks! I didn't see anything like that in the vMix help manual. For all I need here that would actually work fine but a dedicated program seems like a good idea for the future. The Windows Movie Maker is well regarded.
I am a little surprised, after re-watching the YouTube vid, that there isn't a good way to intersperse the input options. In this case, I'm just lopping the end of one and grafting on the other in its place. If I wanted to add PowerPoints or music or whatever else, some drag-and-drop would be handy.
Cheers and good luck on your projects, sh
