Need help with basic editing
Joined: 10/30/2014(UTC) Posts: 16 Location: Asheville, NC
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi All,
I am new to this and can't find a guide on how to cut and paste videos. I shot a podcast and reshot the ending. All I need to do now is put the new ending in place of the original. I have both of the vids on the screen and played with the fade control but I don't know how to add one to the other or how to save the working project.
Any ideas? Thanks, sh
Win7 64-bit i5 processor 8 GB RAM recorded in MPEG VMIX Basic HD
Well, vMix is not the best solution for that. In theory you could: - load your two recordings into two different video inputs - cue each one to where you want to start playing - click "Cut" on the first video to get it into Output - Start recorder and immediately start plaing the first video - when first video ends, cut/fade to the second video and play it - when second video ends, stop recording (some of the above could be automated with shortcuts and autostarts) But you would be much better of with any video editor - lots of free ones. Or a dedicated video splitter, such as http://applian.com/replay-media-splitter/Good luck!
 1 user thanked richardgatarski for this useful post.
Thanks! I didn't see anything like that in the vMix help manual. For all I need here that would actually work fine but a dedicated program seems like a good idea for the future. The Windows Movie Maker is well regarded.
I am a little surprised, after re-watching the YouTube vid, that there isn't a good way to intersperse the input options. In this case, I'm just lopping the end of one and grafting on the other in its place. If I wanted to add PowerPoints or music or whatever else, some drag-and-drop would be handy.
Cheers and good luck on your projects, sh
