STADIORADIO
#1 Posted : Wednesday, January 14, 2015 8:38:07 AM(UTC)
STADIORADIO
This card works with Vmix?
I have this error
AddNewInput
Capture Device Is Not Supported, Device Reported the following: Video Capture
32595559-0000-0010-8000-00aa00389b71
is there a solution?
Thank You
Charssay
#2 Posted : Wednesday, January 14, 2015 8:59:47 AM(UTC)
Charssay
Already use this card in the past, never succeed to have any feed. Give a Black screen. I cannot advice it to any one. If you buy it recently, ask for a refund and for the same price, take an avermedia
C.
STADIORADIO
#3 Posted : Wednesday, January 14, 2015 9:13:55 AM(UTC)
STADIORADIO
nooooooooooo :((((
STADIORADIO
#4 Posted : Wednesday, January 14, 2015 9:35:05 AM(UTC)
STADIORADIO
this
Avermedia C727 Darkcrystal Hd Capture Sdk
STADIORADIO
#5 Posted : Wednesday, January 14, 2015 11:18:44 AM(UTC)
STADIORADIO
it is possible that a card pinnacle, 50 euro, with connessionre firewire functions, and instead a startech pci express, has problems?
however, I can manage up to 768x576, with the composite (yellow) does not work, however, with the hdmi connection the camera sees. my version is 14.0.0.83 x64
Thank You
Charssay
#6 Posted : Thursday, January 15, 2015 6:23:27 AM(UTC)
Charssay
Dear,
It was two years ago when I try this card, I did really remember the setting of when I do this. Only the result of the black screen (what ever the things I try) that I remember very well. Since then, I will never use it again.
But, It will be better, as you can see through out the forum, to get a capture card that have a good result with vmix. Some are cheap (like Avermedia) and some others are expensive , But this depend on what you really intend to do with it.
If you succeed to have a signal with the HDMI, why not forget the composite. In the HDMI you will get a crystal clear image what ever the resolution you will use under 1920*1080
Rgds
Charles
thanks 1 user thanked Charssay for this useful post.
STADIORADIO on 1/15/2015(UTC)
