Streaming different outputs at the same time
I may be in need of having VMIX to stream to two different streaming solutions - at the same time. One is receiving the MAIN out and the other is receiving an INPUT {number} instead.
Is this possible with VMIX 14 ??
BR /Ulrik
I don't think this is possible with Vmix. You could try a software called splitcam to do this: Use the camera that you want to stream seperatly in splitcam, and create a virtual output that you use in vmix. You can stream the input using splitcam. http://splitcamera.com/I bookmarked this a while a go, but never really tried it. Good luck!
could also use AmarectTv Live to split your source first use Amarec as regular input source into vMix but also somewhere else , FMLE maybe ?
