um@equilive.dk
#1 Posted : Thursday, January 1, 2015 6:41:31 AM(UTC)
um@equilive.dk
I may be in need of having VMIX to stream to two different streaming solutions - at the same time. One is receiving the MAIN out and the other is receiving an INPUT {number} instead.
Is this possible with VMIX 14 ??
BR
/Ulrik
Ittaidv
#2 Posted : Thursday, January 1, 2015 7:59:09 AM(UTC)
Ittaidv
I don't think this is possible with Vmix. You could try a software called splitcam to do this:
Use the camera that you want to stream seperatly in splitcam, and create a virtual output that you use in vmix. You can stream the input using splitcam. http://splitcamera.com/
I bookmarked this a while a go, but never really tried it. Good luck!
#3 Posted : Thursday, January 1, 2015 8:21:48 AM(UTC)
Was thanked: 1009 time(s) in 831 post(s)
could also use AmarectTv Live to split your source first
use Amarec as regular input source into vMix but also somewhere else , FMLE maybe ?
