#1 Posted : Thursday, November 17, 2011 10:06:53 AM(UTC)
Was thanked: 4788 time(s) in 1643 post(s)
There has been a bit of a delay on the release of vMix 2012 v2, but I think the new features will be worth it:
* Support for 4 toggled overlays at a time.
* RTMP Support
* New VideoList feature, open up multiple video clips as a single input.
* RGB24 Capture Card support (for older cards and virtual capture devices)
Plus the following fixes:
* Fixed MultiCorder format issue.
* Fixed playback issue when there are duplicate items in the PlayList.
* QuickPlay of Photos input would sometimes go back to first photo.
thanks 3 users thanked admin for this useful post.
jan211984 on 11/17/2011(UTC), ELCHAPIN on 11/17/2011(UTC), dundurs on 11/18/2011(UTC)
Famous Pictures
#2 Posted : Friday, November 18, 2011 2:28:59 AM(UTC)
Famous Pictures
Looking forward to purchasing this new version.
Will it include:
Master VU meters
Saving all user configurable settings (record, cameras, etc.)
Thanks!
ELCHAPIN
#3 Posted : Friday, November 18, 2011 5:31:05 AM(UTC)
ELCHAPIN
Thanks Martin.
the new features, good work, always
I need to add background audio tracks
so easy (MP3, WAW) Extra
separated from the original audio Video
control balance of both.
consider using UV Meter display.
You need to put titles only and not to use camera.
the new features are super perfect
Espanish ______________________
Gracias Martin .
the new features , buen trabajo , siempre
necesito agregar pistas de fondo de audio
de forma facil (MP3 , WAW) Extra
separado del audio original del Video
balance control de ambos .
mejor si lleva UV display Meter .
Se necesita al colocar titulos solamente y no usar camara .
the new features son super perfectas
#4 Posted : Friday, November 18, 2011 11:57:05 PM(UTC)
MP3/WAV support will also be in v2.
ELCHAPIN on 11/20/2011(UTC)
ELCHAPIN
#5 Posted : Sunday, November 20, 2011 1:38:30 PM(UTC)
ELCHAPIN
Thank you for that support.
're a genius
would be nice to be easily accessible
to cut and edit the track.
if you can.
It is super Vmix2011 but it closed with a flourish the year.
UserPostedImageUserPostedImage
ber142
#6 Posted : Friday, December 2, 2011 9:50:35 AM(UTC)
ber142
Will it include (configurable) keyboard shortcuts for basic functions like enable/disable fullscreen, pause/resume rendering/inputs, etc?
Thanks.
zadark
#7 Posted : Monday, December 19, 2011 7:21:49 AM(UTC)
zadark
RTMP SUpport is a out server stream? or input stream
#8 Posted : Tuesday, December 20, 2011 9:35:27 AM(UTC)
vMix 2012 v2 has gone into internal testing, so new features are now locked.
It should hopefully be released sometime in January.
Some additional features:
* Option to record to a MPEG-2 Transport Stream. This resolves audio sync issues editing with Sony Vegas and Sony Vegas Movie Studio and also allows
the playback of incomplete recordings.
* Selectable MPEG-2 Bit Rates. (4, 8, 16, 25 and 50Mbit available)
* Customisable Input Size (handy for those with large screens)
* vMix Virtual Audio Capture to make recording audio as easy as possible under Windows 7.
Supports a single 44100hz 16bit (CD Quality) format and can be used with vMix, FMLE and Expression Encoder.
* Master Audio level available in the mixer.
ELCHAPIN on 12/20/2011(UTC), jan211984 on 12/20/2011(UTC)
#9 Posted : Sunday, January 8, 2012 2:58:14 AM(UTC)
A test version is now available here:
http://forums.vmix.com.au/default.aspx?g=posts&t=285
ELCHAPIN on 1/8/2012(UTC)
