Joined: 1/13/2010(UTC) Posts: 5,366  Location: Gold Coast, Australia Was thanked: 4788 time(s) in 1643 post(s)
There has been a bit of a delay on the release of vMix 2012 v2, but I think the new features will be worth it:
* Support for 4 toggled overlays at a time. * RTMP Support * New VideoList feature, open up multiple video clips as a single input. * RGB24 Capture Card support (for older cards and virtual capture devices)
Plus the following fixes:
* Fixed MultiCorder format issue. * Fixed playback issue when there are duplicate items in the PlayList. * QuickPlay of Photos input would sometimes go back to first photo.
Martin vMix
 3 users thanked admin for this useful post.
Looking forward to purchasing this new version.
Will it include:
Master VU meters
Saving all user configurable settings (record, cameras, etc.)
Thanks!
Thanks: 46 times Was thanked: 2 time(s) in 2 post(s)
Thanks Martin. the new features, good work, always I need to add background audio tracks so easy (MP3, WAW) Extra separated from the original audio Video control balance of both. consider using UV Meter display. You need to put titles only and not to use camera. the new features are super perfect
Espanish ______________________
Gracias Martin . the new features , buen trabajo , siempre necesito agregar pistas de fondo de audio de forma facil (MP3 , WAW) Extra separado del audio original del Video balance control de ambos . mejor si lleva UV display Meter . Se necesita al colocar titulos solamente y no usar camara . the new features son super perfectas
MP3/WAV support will also be in v2.
Thank you for that support. 're a genius would be nice to be easily accessible to cut and edit the track. if you can. It is super Vmix2011 but it closed with a flourish the year.
Joined: 12/2/2011(UTC) Posts: 77 Location: Europe / The Netherlands
Will it include (configurable) keyboard shortcuts for basic functions like enable/disable fullscreen, pause/resume rendering/inputs, etc?
Thanks.
RTMP SUpport is a out server stream? or input stream
vMix 2012 v2 has gone into internal testing, so new features are now locked. It should hopefully be released sometime in January.
Some additional features:
* Option to record to a MPEG-2 Transport Stream. This resolves audio sync issues editing with Sony Vegas and Sony Vegas Movie Studio and also allows the playback of incomplete recordings.
* Selectable MPEG-2 Bit Rates. (4, 8, 16, 25 and 50Mbit available)
* Customisable Input Size (handy for those with large screens)
* vMix Virtual Audio Capture to make recording audio as easy as possible under Windows 7. Supports a single 44100hz 16bit (CD Quality) format and can be used with vMix, FMLE and Expression Encoder.
* Master Audio level available in the mixer.
Martin vMix
