ClementN
#1 Posted : Tuesday, December 16, 2014 1:02:22 AM(UTC)
ClementN
Romania
Hello everyone,
I recorded a lot of files in .avi format now I have big problems to edit them in Premiere Pro CC
We were able to import them in Premiere and even edit them ( with some crashes of Premiere Pro)
But now the export ( rendering ) is not possible as the Premiere Pro crashes a couple of minutes after starts rendering.
Any suggestion is much appreciated.
Best regards,
Clement
ceejay7777
#2 Posted : Tuesday, December 16, 2014 2:13:42 AM(UTC)
ceejay7777
What codec did you use? Check with MediaInfo and post result.
#3 Posted : Tuesday, December 16, 2014 9:27:08 AM(UTC)
I have had good luck with the Cineform codec.
Most of the others have either been problematic with Premiere Pro CS5 or are too large for my liking.
Are you able to convert the files with some other piece of software?
Perhaps play back through vMix and record to a different codec...
ClementN
#4 Posted : Tuesday, December 16, 2014 1:24:36 PM(UTC)
ClementN
Romania
Hello Ceejay7777, Thank you.
The Mediainfo output is bellow.
IceStream, I tried to convert them without any success.
Probably I'll try the re-recording vMix solution soon if the fix will not appear .
Complete name : G:\Microsoft_Summit_2014\Santal\Footage\Day1\microsoft_santal_z1 - 12 November 2014 - 01-56-59 PM.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 572 MiB
Duration : 1mn 0s
Overall bit rate : 79.0 Mbps
Video
Format : JPEG
Codec ID : MJPG
Duration : 1mn 0s
Bit rate : 77.5 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 1.495
Stream size : 561 MiB (98%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 1mn 0s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 11.1 MiB (2%)
Alignment : Aligned on interleaves
Interleave, duration : 20 ms (0.50 video frame)
Interleave, preload duration : 40 ms
HighViewSport
#5 Posted : Tuesday, December 16, 2014 2:11:49 PM(UTC)
HighViewSport
HI Guys, I came across this issue recently as well. I too have premier pro CC 2014. The fix was to downgrade the blackmagic drivers on my system to 10.1.1. It seems Adobe are aware there is an issue with current drivers (10.3.2) and premier pro CC 2014. Look on adobe support page to get drivers.
Hope this helps :)
ceejay7777
#6 Posted : Wednesday, December 17, 2014 3:10:39 AM(UTC)
ceejay7777
Yep, looks like your version of Premiere Pro doesn't like the MJPEG codec. I don't use Premiere as a rule, but I recorded some MJPEG AVI in vMix and the file played and rendered OK in PP CS4.
The suggestion to re-record in vMix sounds like the best bet. I also use Cineform most of the time and it works in my NLE of choice - Sony Vegas.
ClementN
#7 Posted : Wednesday, December 17, 2014 3:06:31 PM(UTC)
ClementN
Romania
Thank you all for the suggestions.
HighViewSport, the rolling back drivers is a solution only for future recording?
It will not fix the already recorded files. Is that right?
HighViewSport
#8 Posted : Wednesday, December 17, 2014 4:08:49 PM(UTC)
HighViewSport
Yes, unfortunately thats correct.
What I did was playout the original recording from vmix and connected my atomos ninja recorder to the output and recorded a prores version.
Premier pro cc 2014 accepts that fine.
I know you have a lot of recordings so could be a pain but it is a solution.
You could also try convert the film using handbrake. I personally try avoid converting all costs. Have not converted a file for years now :)
Good luck, Bryan
