r@wisla
#1 Posted : Saturday, November 15, 2014 6:59:23 AM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
Following this thread: http://forums.vmix.com.a....aspx?g=posts&t=2980
My request is, so SetImage function could be managed with shortcuts too.
Just like that :)
On a basketball scoreboard that we have to use the fouls representation is done with images, not text...
Thanks in advance.
r@wisla attached the following image(s):
kjpcrane
#2 Posted : Saturday, November 29, 2014 10:18:59 AM(UTC)
kjpcrane
Please make up date where you can add images via a short cut if this can all ready happen please explain
tdurhamjr
#3 Posted : Saturday, November 29, 2014 4:08:11 PM(UTC)
tdurhamjr
Was thanked: 26 time(s) in 21 post(s)
Here is the page that list all of the shortcuts that can be added (called) via API which sounds like what you need to do.
http://cdn.vmixhd.com/he...utFunctionReference.html
Here is the link that describes the API call function:
http://cdn.vmixhd.com/help14/DeveloperAPI.html
I think this information will get you what you need.
Tim
r@wisla
#4 Posted : Saturday, November 29, 2014 5:14:34 PM(UTC)
r@wisla
tdurhamjr, I think he meant this: http://forums.vmix.com.a....aspx?g=posts&t=3022
tdurhamjr
#5 Posted : Saturday, November 29, 2014 11:07:16 PM(UTC)
tdurhamjr
yep, I believe you are correct. Thanks for clarifying :)
