Introducing SmartIMAG, touch control of IMAG input selection
Below a link to a brief demo of a very early beta version of an application used to control which vMix input should go to IMAG (image magnification, typically a live cam projected at stage). Not sure if we will offer this to other users. Needs a Windows 8 laptop with a touch screen, an HDMI input device (eg Magewell dongle), so it gets kind of expensive. Perhaps an Arduino/Rasbberry Pi solution might be more economical, As I write this I realize that it would be very easy to control the Output instead of a Fullscreen Display. What do you think?
Joined: 12/29/2013(UTC) Posts: 54 Location: Mississauga, Canada
Thanks: 10 times Was thanked: 3 time(s) in 3 post(s)
richardgatarski wrote:Perhaps an Arduino/Rasbberry Pi solution might be more economical. In our case (in a mosque), we typically switch between one camera, some images, and a PC showing powerpoint slides, and we don't need a separate preview besides the vMix main window... So I've set up an inexpensive wireless numeric keypad hooked up to a Raspberry Pi. Each key on the keypad can be programmed (via the vMix API) to show specific inputs -- camera only, powerpoint only, both using picture-in-picture, black screen, logo image, etc.. The wireless numeric keypad is easy to move around with and independent of what's being done on the vMix PC keyboard/desktop, so it's a very convenient alternative to the built-in vMix keyboard shortcuts or mouse clicks. I can share the setup procedure here, if anyone is interested.
@ Rehan
I would be very interested. (perhaps you should start a new thread so as not to be confused with Richard's SmartIMAG)
Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
Looks good, would service as a viable replacement for an ATEM in my case.
