Delay Recording - ShortCuts
Joined: 11/19/2013(UTC) Posts: 129 Location: Hobart Tasmania Australia
Thanks: 13 times Was thanked: 11 time(s) in 8 post(s)
Hi
Sorry this might be simple but which shortcut turns off "REC" in a delay recording
If any can help.
Tried "StopRecording" shortcut but get "Recording has not been configured" so I guess that refers to the "Recording Setup"
Thanks Ash
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ Ash
Not sure I understand... The video delay only records to disc when you "Save", otherwise, there is no "recording" per se, just a delay buffer (afaik).
Hi The red "REC" button in image below. If it is pressed it stops the buffering to the disk. Ash attached the following image(s):  delay_rec.png (63kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
@ Ash
I don't think there is a 'shortcut' for that... (yet!) But it would certainly add some creative possibilities, especially if the playback could also be controlled with a jog wheel. As it stands, you are pretty much limited to using the mouse for any kind of "replay" manipulation. The disadvantage, of course, is that you lose any concurrent moments you may want to 'review' while the 'buffer' is not in 'REC' mode.
Joined: 9/8/2014(UTC) Posts: 244 Location: Southaven MS
Thanks: 12 times Was thanked: 26 time(s) in 21 post(s)
Ice, Until the new Instant Replay is released, one work around on missing the concurrent moments is to also have a video delay set for your "ouput".
So if you have 2 cameras, you would add the video delay for camera 1 and camera 2, but also for the vMix Ouput. Then if you stop the buffer on Camera 1 and it is the live camera, you are still capturing camera 1 via vMix Output.
Tim
Well that's disappointing. I would have liked to be able to control this with shortcuts.
Thanks for clarifying.
Cheers Ash
@ Ash
I'm guessing it's possible since a mouse click activates and de-activates it. It is just a matter of putting it in as a feature request...
