Ash
#1 Posted : Friday, November 21, 2014 1:33:17 AM(UTC)
Ash
Was thanked: 11 time(s) in 8 post(s)
Hi
Noticed this behavior sometime ago and thought it might right itself with all the ver 14 updates. See pic below.
Using vMix 13 and 14.
The MP4 was recorded using version 14.0.0.? (cant recall) but has seemed to always have this problem.
Both systems setup to display 1280 x 720 PAL 50p
Any ideas or is their something that can be done to fix ?
Ash attached the following image(s):
#2 Posted : Friday, November 21, 2014 2:26:49 AM(UTC)
Was thanked: 4749 time(s) in 1632 post(s)
Click the cog icon underneath the input in each version and compare
the information under the Advanced tab to see if anything is different.
Ash
#3 Posted : Friday, November 21, 2014 2:32:42 AM(UTC)
Ash
Hi
Only diff is on 14 under the Frame Rate their is a deinterlacing textbox with "none" assigned.
13 does not have this.
Ash
#4 Posted : Friday, November 21, 2014 2:40:18 AM(UTC)
Did you check under the Advanced tab? There should be a list of filters such as Video Mixing Renderer etc.
Ash
#5 Posted : Friday, November 21, 2014 2:50:48 AM(UTC)
Ash
Both appear to be the same
Ash
#6 Posted : Friday, November 21, 2014 3:17:03 AM(UTC)
Ash
Hi again
Just a thought would the "Enabling custom AVI codecs" affect the display of this file?
Only diff I can see between both versions.
But I cant see a vMix64.exe.config.
EDIT:
Ok got it and changed but still the same
If I change the Settings to 1920 x 1080 50p it fixes problem but I need 720p.
Ash
#7 Posted : Friday, November 21, 2014 1:08:30 PM(UTC)
I've just run some tests, setting up vMix as 1280x720 50p and doing a MP4 recording and then
bring that video back into vMix for playback and it all looked ok.
Perhaps there is an odd graphics card issue here, what graphics card is that system running? Is it the latest drivers?
(If so, what version?)
Ash
#8 Posted : Friday, November 21, 2014 5:46:37 PM(UTC)
Ash
Hi
Its an ASUS G750JZ with GTX880M 4GB running Win8.1 the drivers are up to date. Will post version details later today.
But this also occurs on other machines. My old desktop is used to create graphics has the same result and its running an old 460
Why only on v14 and not v13?
Will do some more tests.
Ash
#9 Posted : Friday, November 21, 2014 11:21:45 PM(UTC)
I tested on an ASUS G750 as well (GTX 765M). Maybe there is an odd setting that is different in vMix 14.
Could you email me your settings file (export it from Settings -> Export) and I will import it and run the following tests:
1. Create MP4 recording at 1280x720 50p
2. Add the recording back in vMix and play it back.
Ash
#10 Posted : Saturday, November 22, 2014 4:10:32 PM(UTC)
Ash
Sent the settings export to you
Graphics driver is 340.52 Rel 7/29/2014
EDIT ----
Updated driver to 344.75 Rel 11/18/2014 = no change
Ok so tried every other Output Resolution and Master Frame Rate resolution and vMix 14 displays the file correctly.
Tried other captured files and behavior is same for all.
i.e. Settings -> Output Size and Master Frame Rate - all ok except 1280 x 720 @ 25p / 50i /50p even tho the mp4 file was captured as 1280 x 720 50p or 25p
Is there something weird about my mp4 codec?
#11 Posted : Saturday, November 22, 2014 5:26:18 PM(UTC)
Here's the test I have just run, try the same thing and see what results you get.
1. Using provided settings export and NVIDIA Graphics Driver 344.75
2. Added new Colour input set to Colour Bars
3. Created MP4 Recording at 1280x720 50p 25mbps for 20 seconds
4. Added recording as input and played it back.
Screenshot of results attached.
admin attached the following image(s):
Ash on 11/22/2014(UTC)
Ash
#12 Posted : Saturday, November 22, 2014 5:56:08 PM(UTC)
Ash
Umm nope
But think I found solution.
Checked out NVIDIA Control Panel -> Program Settings and changed setting to Use Global Setting (see pic)
Also set Global Settings tab -> Preferred graphics processor to Auto-select
and correct rendering now appears in vMix.
So question - what setting to use to ensure that vMix uses the NVIDIA GPU rather than the integrated graphics?
ovinas
#13 Posted : Saturday, November 22, 2014 6:12:28 PM(UTC)
ovinas
vMix is NOT a 3D program, so modifying these options won't change anything. Or are you using 3D glasses to operate vMix? ;-)
Ash
#14 Posted : Saturday, November 22, 2014 6:21:15 PM(UTC)
Ash
Ha nope 8-)
#15 Posted : Saturday, November 22, 2014 11:37:24 PM(UTC)
Actually the 3D settings are important as vMix uses Direct3D for video processing.
I've done some research and your G750 also has integrated graphics alongside the nvidia graphics
while my G750 with the 765M only has nvidia graphics.
Unfortunately the use of integrated graphics alongside the nvidia tends to drag down the performance of both.
Auto-select is probably the best option for now you can also try downloading the latest intel graphics drivers.
Ash
#16 Posted : Sunday, November 23, 2014 2:00:25 AM(UTC)
Ash
Thank you Martin
Hope it wasnt a total waste of your time.
Have you been able then to replicate the same issue with the 3D settings?
Interesting subject.
Regards
Ash
EDIT --
So its not possible to force/coerce vMix to use the NVIDIA engine will the system default to integrated? Can this be controlled?
