gahan
#1 Posted : Saturday, November 15, 2014 6:04:13 AM(UTC)
gahan
I need to start recording in some cases from web page.
Is there any way to send some API command for this - file record name must be set as url parameter.
Ivan videv
daniel514
#2 Posted : Saturday, November 15, 2014 12:42:41 PM(UTC)
daniel514
Canada
Was thanked: 16 time(s) in 16 post(s)
gahan wrote:
Ivan videv
I look for the same function, is it posssible?
DYosua
#3 Posted : Saturday, November 15, 2014 6:38:38 PM(UTC)
DYosua
Was thanked: 15 time(s) in 12 post(s)
I don't believe you can specify a filename through the API, but you can start/stop recording through it. The link to start a recording would be:
http://[Insert your vMix web interface link here]/API/?Function=StartRecording
You can use the "StopRecording" function to stop the recording. It uses the recording format and naming conventions you have configured in vMix. Having a file that contains the start time of the recording in hh:mm:ss for instance would eliminate the chance of accidentally replacing an already recorded file.
