Joined: 12/20/2012(UTC) Posts: 81  Location: INDIA, TAMILNADU Thanks: 5 times Was thanked: 8 time(s) in 6 post(s)
HOW TO CONNECT WIFI CAMERA IN VMIX (LIKE GOPRO)
Joined: 12/19/2013(UTC) Posts: 601   Location: Belgium Thanks: 75 times Was thanked: 91 time(s) in 75 post(s)
Joined: 9/8/2014(UTC) Posts: 244 Location: Southaven MS
Thanks: 12 times Was thanked: 26 time(s) in 21 post(s)
I spent a couple of hours last night downloading and trying all the different apps for wifi streaming and I found all of them to be worthless and nothing you would include in a live stream. If you were street reporting somewhere and it was crap or nothing, then the smart phone stream would just have to do. You can either 1) get an HDMI Wireless Transmitter which actually works pretty well if the distance is not too far. You can get those from $200 to $10,000 depending on how far you want to transmit.
I would invest in a 500 or 1000 foot roll of HD SDI cable and just make you some long SDI cables for your cameras (you can buy inexpensive HDMI to SDI converters). If that is not an option then the wireless HDMI transmitters will be the only likely solution for good quality video.
tdurhamjr wrote:I spent a couple of hours last night downloading and trying all the different apps for wifi streaming and I found all of them to be worthless and nothing you would include in a live stream. If you were street reporting somewhere and it was crap or nothing, then the smart phone stream would just have to do. You can either 1) get an HDMI Wireless Transmitter which actually works pretty well if the distance is not too far. You can get those from $200 to $10,000 depending on how far you want to transmit.
We also use cheap sdi converters. I can vouch for this approach, it's the most reliable option. Using Wifi will always degrade the image to low framerate and resolution, plus it might give a lot of hickups. I can only imagine to use wifi if i would not want to buy expensive equipment. You can do this with a cheap laptop, the free version of vmix and a cheap gopro or smartphone. I would not expect any groundbreaking results from it, but it's a way to get started and see how things work..
