r@wisla
#1 Posted : Sunday, November 2, 2014 2:47:45 PM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
I can't add shortcut to change image in title/xaml input.
Adding Shortcuts.
- Choosing function: SetImage
- Choosing input: Title/XAML input
Then, there is only list of text titles, no option to choose image element.
So, I guess SetImage function can't be used with shortcuts. Am I right?
r@wisla
#2 Posted : Sunday, November 2, 2014 6:07:39 PM(UTC)
r@wisla
Is += value supported for SetText function in API?
I'm trying to launch the following URL (from web browser)
http://localhost:8088/API/?Function=SetText&Input=4&SelectedIndex=2&Value=+=4
and it gives me =4 value. It doesn't increment previous integer value.
Funny thing is the -= works fine.
Or maybe it's because some not compatible way that "+" charakter is send by browser...? += value works fine with shortcuts, but I'd like to use it with API.
#3 Posted : Sunday, November 2, 2014 11:00:20 PM(UTC)
Groups ready for retrieval: Administrators
Was thanked: 4759 time(s) in 1633 post(s)
The value will need to be correctly URL encoded for some characters.
For example
Value=%2B%3D4
for Value=+=4
r@wisla on 11/3/2014(UTC), stigaard on 8/7/2017(UTC)
r@wisla
#4 Posted : Monday, November 3, 2014 4:55:36 AM(UTC)
r@wisla
Thank You.
Could You also clarify issue with SetImage function in Shortcuts?
#5 Posted : Monday, November 3, 2014 5:04:34 AM(UTC)
Yes, SetImage only works with the API.
tubbis_2
#6 Posted : Wednesday, November 25, 2015 10:31:39 AM(UTC)
tubbis_2
Does the Value=+=1 and Value=-=1 work for a countdown as well? I don't get it to work no matter how I encode so perhaps it won't work. I created a workaround so it's not a big deal if it doesn't work. Just asking...
Ario
#7 Posted : Wednesday, July 14, 2021 12:42:42 AM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
The solution to get +1 working for the score, is in here:
https://forums.vmix.com/....aspx?g=posts&t=2980
I asked vMix to add this to the incomplete info that is now on
https://www.vmix.com/kno...n-vmix-with-the-keyboard
#8 Posted : Wednesday, July 14, 2021 12:50:51 AM(UTC)
Thanks for the link to this post ;-)
