Joined: 8/5/2013(UTC) Posts: 280  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
I can't add shortcut to change image in title/xaml input.
Adding Shortcuts.
- Choosing function: SetImage - Choosing input: Title/XAML input
Then, there is only list of text titles, no option to choose image element.
So, I guess SetImage function can't be used with shortcuts. Am I right?
Is += value supported for SetText function in API?
I'm trying to launch the following URL (from web browser)
http://localhost:8088/API/?Function=SetText&Input=4&SelectedIndex=2&Value=+=4
and it gives me =4 value. It doesn't increment previous integer value.
Funny thing is the -= works fine.
Or maybe it's because some not compatible way that "+" charakter is send by browser...? += value works fine with shortcuts, but I'd like to use it with API.
Joined: 1/13/2010(UTC) Posts: 5,320  Location: Gold Coast, Australia Was thanked: 4720 time(s) in 1617 post(s)
The value will need to be correctly URL encoded for some characters. For example
Value=%2B%3D4
for Value=+=4
Thank You.
Could You also clarify issue with SetImage function in Shortcuts?
Yes, SetImage only works with the API.
Joined: 11/21/2013(UTC) Posts: 32 Location: Stockholm
Thanks: 2 times Was thanked: 5 time(s) in 5 post(s)
Does the Value=+=1 and Value=-=1 work for a countdown as well? I don't get it to work no matter how I encode so perhaps it won't work. I created a workaround so it's not a big deal if it doesn't work. Just asking...
Thanks: 185 times Was thanked: 20 time(s) in 17 post(s)
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Ario  Thanks for the link to this post ;-)
