Short cut key(s) For Overlay
Joined: 9/26/2014(UTC) Posts: 104  Location: Canada Thanks: 39 times Was thanked: 5 time(s) in 5 post(s)
Hi
Is there a shortcut key for removing the overlay and another for adding it again ?
I am particlualrly interested in the "Social" overlay. I would like to be able to easily add and remove the twitter flow, once it is setup.
Thank's
Whit
Joined: 9/8/2014(UTC) Posts: 244 Location: Southaven MS
Thanks: 12 times Was thanked: 25 time(s) in 21 post(s)
calamityjane wrote:Hi
Thank's
Whit Whit, You can turn an overlay on or off with any shortcut key you assign. You click on SETTINGS in the top right corner: Settings> Shortcuts > Add Key = short cut key Function = OverlayInput1 (for overlay #1) Duration = Duration you want (ie if you want the overlay to be 5 second = 5000) (I believe 0 means it is permanent). Input = the input you want to be used as the overlay Do the same thing but to turn the overlay off Function - OverlayInput1Off (to turn off overlay input 1). You will assign a different shortcut key to turn it off Tim
 1 user thanked tdurhamjr for this useful post.
Tim
Thanks TimWhit
Hi Tim
I actually ended up using this shortcut key assignment;
A overlayinput1 5000 Blank2
Thus when I set it up origiannlyy the overlay shows Using the A key it rmoves the overaly Hitting the A key again bring the overlay back in
Neat and effective
Thanks again Tim for steering me to this function
Whit
