calamityjane
#1 Posted : Friday, October 24, 2014 5:03:57 PM(UTC)
calamityjane
Hi
Is there a shortcut key for removing the overlay and another for adding it again ?
I am particlualrly interested in the "Social" overlay. I would like to be able to easily add and remove the twitter flow, once it is setup.
Thank's
Whit
tdurhamjr
#2 Posted : Friday, October 24, 2014 6:29:26 PM(UTC)
tdurhamjr
Was thanked: 26 time(s) in 21 post(s)
calamityjane wrote:
Hi
Thank's
Whit
Whit, You can turn an overlay on or off with any shortcut key you assign. You click on SETTINGS in the top right corner:
Settings> Shortcuts > Add
Key = short cut key
Function = OverlayInput1 (for overlay #1)
Duration = Duration you want (ie if you want the overlay to be 5 second = 5000) (I believe 0 means it is permanent).
Input = the input you want to be used as the overlay
Do the same thing but to turn the overlay off
Function - OverlayInput1Off (to turn off overlay input 1). You will assign a different shortcut key to turn it off
Tim
thanks 1 user thanked tdurhamjr for this useful post.
calamityjane on 10/24/2014(UTC)
calamityjane
#3 Posted : Friday, October 24, 2014 8:15:25 PM(UTC)
calamityjane
Key = short cut key
Tim
Thanks Tim
Whit
calamityjane
#4 Posted : Tuesday, October 28, 2014 8:31:17 AM(UTC)
calamityjane
Hi Tim
I actually ended up using this shortcut key assignment;
A overlayinput1 5000 Blank2
Thus when I set it up origiannlyy the overlay shows
Using the A key it rmoves the overaly
Hitting the A key again bring the overlay back in
Neat and effective
Thanks again Tim for steering me to this function
Whit
