i hacked
#1 Posted : Sunday, October 19, 2014 3:19:24 AM(UTC)
i hacked
hello guys i need help on how to add or make 3 audio channels on vmix
English
German
french
thank you
i hacked
#2 Posted : Sunday, October 19, 2014 3:29:07 AM(UTC)
i hacked
i have another question on duration
it start at a place i set the time to but it can not stop at a point where i stop it
Len56
#3 Posted : Sunday, October 19, 2014 9:24:11 AM(UTC)
Len56
English
German
french
thank you
Go to settings > Audio Outputs and select MASTER OUTPUT 1-2 then go to A and select 3-4 - then go to B and select 5-6.
Make sure you audio card you are using is selected in MASTER, A and B
i hacked
#4 Posted : Tuesday, October 21, 2014 9:26:32 AM(UTC)
i hacked
Len56 wrote:
English
German
french
thank you
Audio Outputs can not be found what i see is display.options,performance,decoders,recording,color space,external output, audio,web....... but on audio i can not see MASTER OUTPUT 1-2
all i can see is
default audio render
master sample rate
master bit rate
thank you
Len56
#5 Posted : Tuesday, October 21, 2014 9:59:00 AM(UTC)
Len56
What version of vMix are you using, I am using vMix HD, if you are using the free version that maybe the problem.
But underneath audio in settings I can see in my version AUDIO OUTPUTS in there is a
Master Output 1-2
Headphones 1-2
A1-2
B1-2
Default Bus for New Inputs Master
I don't know how to place a picture here otherwise I would to show you.
Len56
#6 Posted : Tuesday, October 21, 2014 10:00:15 AM(UTC)
Len56
Master Output 1-2
Headphones 1-2
A1-2
B1-2
[img][/img]
Len56 attached the following image(s):
vMix Audio Outputs.jpg (126kb) downloaded 10 time(s).
i hacked
#7 Posted : Tuesday, October 21, 2014 11:57:52 AM(UTC)
i hacked
Master Output 1-2
Headphones 1-2
A1-2
B1-2
[img][/img]
wowo my version is version 9 HD
i hacked
#8 Posted : Saturday, December 27, 2014 4:10:29 AM(UTC)
i hacked
Master Output 1-2
Headphones 1-2
A1-2
B1-2
[img][/img]
please i have version 10.0.0.59
but i can not fine this audio option
Len56
#9 Posted : Saturday, December 27, 2014 10:03:42 AM(UTC)
Len56
Why don't you update to the latest version, just go to the download page, download and install, it should be a free upgrade.
Your version dose not have this in it.
#10 Posted : Sunday, December 28, 2014 10:29:24 AM(UTC)
@ Len56 & I hacked
Upgrading from vMix 10 to 14 might not be possible for free.
vMix 12 upgrade may require an upgrade fee depending on when you purchased:
http://forums.vmix.com.a....aspx?g=posts&t=1972
i hacked
#11 Posted : Tuesday, December 30, 2014 8:46:25 PM(UTC)
i hacked
IceStream wrote:
@ Len56 & I hacked
the version 10 can not even play audio by SDI i try it and no sound
no sound to the out put
h2video.nl
#12 Posted : Wednesday, December 31, 2014 7:05:05 AM(UTC)
h2video.nl
what would be nice is to be able to record multichannel as well. maybe something for vmix 15....
i hacked
#13 Posted : Wednesday, December 31, 2014 11:14:00 AM(UTC)
i hacked
guys i have problem with Derklink 4K extrem capture card
it fail to send audio out From SDI
but the HDMI is ok
i connect to harmonic encoder but no audio
i have bean working on more than 3 days now
video is ok but no audio
