How can i add multiple audio channels to Vmix
hello guys i need help on how to add or make 3 audio channels on vmix
English German french
thank you
i have another question on duration it start at a place i set the time to but it can not stop at a point where i stop it
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
i hacked wrote:hello guys i need help on how to add or make 3 audio channels on vmix
thank you Go to settings > Audio Outputs and select MASTER OUTPUT 1-2 then go to A and select 3-4 - then go to B and select 5-6. Make sure you audio card you are using is selected in MASTER, A and B
Len56 wrote:i hacked wrote:hello guys i need help on how to add or make 3 audio channels on vmix
thank you Go to settings > Audio Outputs and select MASTER OUTPUT 1-2 then go to A and select 3-4 - then go to B and select 5-6. Make sure you audio card you are using is selected in MASTER, A and B Audio Outputs can not be found what i see is display.options,performance,decoders,recording,color space,external output, audio,web....... but on audio i can not see MASTER OUTPUT 1-2 all i can see is default audio render master sample rate master bit rate thank you
What version of vMix are you using, I am using vMix HD, if you are using the free version that maybe the problem.
But underneath audio in settings I can see in my version AUDIO OUTPUTS in there is a Master Output 1-2 Headphones 1-2 A1-2 B1-2
Default Bus for New Inputs Master
I don't know how to place a picture here otherwise I would to show you.
What version of vMix are you using, I am using vMix HD, if you are using the free version that maybe the problem. But underneath audio in settings I can see in my version AUDIO OUTPUTS in there is a Master Output 1-2 Headphones 1-2 A1-2 B1-2 Default Bus for New Inputs Master [img][/img] Len56 attached the following image(s):  vMix Audio Outputs.jpg (126kb) downloaded 10 time(s).You cannot view/download attachments. Try to login or register.
Len56 wrote:What version of vMix are you using, I am using vMix HD, if you are using the free version that maybe the problem.
[img][/img] wowo my version is version 9 HD
[img][/img] please i have version 10.0.0.59 but i can not fine this audio option
Why don't you update to the latest version, just go to the download page, download and install, it should be a free upgrade.
Your version dose not have this in it.
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
the version 10 can not even play audio by SDI i try it and no sound no sound to the out put
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
what would be nice is to be able to record multichannel as well. maybe something for vmix 15....
guys i have problem with Derklink 4K extrem capture card
it fail to send audio out From SDI but the HDMI is ok i connect to harmonic encoder but no audio i have bean working on more than 3 days now video is ok but no audio
