Custom XAML: Viewport3D problems
Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
Hi every one, I'm trying to load a true 3D object into a XAML title, and may be to transform it (rotate) using a storyboard. It looks perfect on Blender, but I get an error when loading into vMix Attached should be the XAML I'm using. The error (in spanish) says: No se puede convertir un objeto de tipo 'System.Windows.Media.Media3D.ModelVisual3D' al tipo 'System.Windows.Media.Visual'Any idea? Saludos, OSCAR. File Attachment(s):  vMix2.xaml (6kb) downloaded 15 time(s).You cannot view/download attachments. Try to login or register.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
See some of the included xaml templates. Everything needs to be included inside a UserControl to work with vMix. That said, i'm not sure 3D objects will work, but you can give it a try.
Martin vMix
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
ogry wrote:Hi every one,
Any idea?
Saludos, OSCAR. I've tried to import Viewport3D into vMix with no luck, same thing goes for webbrowser, MediaPlayer(?) and some other standard XAML element, just as a heads-up. Also, if you get any of these working, send me a massage with how! Cheers, Håvard
What is weird is that you can open it succesfully in Title Designer, but not in my vMix 4K
May be a bug?
Saludos, OSCAR.
