ogry
#1 Posted : Saturday, October 11, 2014 9:44:14 PM(UTC)
ogry
Hi every one,
I'm trying to load a true 3D object into a XAML title, and may be to transform it (rotate) using a storyboard. It looks perfect on Blender, but I get an error when loading into vMix
Attached should be the XAML I'm using.
The error (in spanish) says:
No se puede convertir un objeto de tipo 'System.Windows.Media.Media3D.ModelVisual3D' al tipo 'System.Windows.Media.Visual'
Any idea?
Saludos, OSCAR.
File Attachment(s):
vMix2.xaml (6kb) downloaded 15 time(s).
#2 Posted : Saturday, October 11, 2014 10:31:59 PM(UTC)
See some of the included xaml templates. Everything needs to be included inside a UserControl to work with vMix.
That said, i'm not sure 3D objects will work, but you can give it a try.
Thremir
#3 Posted : Sunday, October 12, 2014 10:00:19 AM(UTC)
Thremir
ogry wrote:
Hi every one,
Any idea?
Saludos, OSCAR.
I've tried to import Viewport3D into vMix with no luck, same thing goes for webbrowser, MediaPlayer(?) and some other standard XAML element, just as a heads-up. Also, if you get any of these working, send me a massage with how!
Cheers,
Håvard
ogry
#4 Posted : Sunday, October 12, 2014 7:15:44 PM(UTC)
ogry
What is weird is that you can open it succesfully in Title Designer, but not in my vMix 4K
May be a bug?
Saludos, OSCAR.
