Joined: 10/10/2014(UTC) Posts: 2 Location: Netherlands
An character per minute setting would be great!
Joined: 2/9/2013(UTC) Posts: 266 Location: Katy, Texas
I agree. I often run text as a ticker showing the current standings after every athlete takes their turn. Over the course of the event, the length of the text grows (and speeds up visually) and I have to go in and manually adjust the time to slow things down again. Changing from a time setting to a speed setting would be fantastic!
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
I had the same problem , so I edited the tile to break out the duration setting so I can set it uesing the API , then the php that feeds in the text does a character count and works out the duration to keep the speed the same
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 203 time(s) in 169 post(s)
