15 Pages«<910111213>»
macjaeger
#201 Posted : Thursday, September 25, 2014 8:55:02 AM(UTC)
macjaeger
I stopped working on the programm a year ago and gave away the source for others to continue, but since then there may have been updates from my side.
LG
#202 Posted : Thursday, September 25, 2014 4:34:16 PM(UTC)
LG
may?
where?
macjaeger
#203 Posted : Thursday, September 25, 2014 4:54:36 PM(UTC)
macjaeger
Oops, i mistyped while reordering the sentence. I wanted to write "there have been no updates from my side" and then decided to change it to "there may be updates from others"... sorry pal, i'm done with this project since i got promoted to a very exciting job that just doesn't leave much time for coding any more (just have been to edinburgh last week professionally...).
television
#204 Posted : Sunday, September 28, 2014 4:53:32 AM(UTC)
television
Hello, Please help me. I can't connect vMix with vMixControler. Use vMix 14 and Windows 7 Ultimate x64.
macjaeger
#205 Posted : Sunday, September 28, 2014 8:13:30 AM(UTC)
macjaeger
Which version of vMix are you running?
Things to check: is web interface in vMix enabled? is correct port set? can you connect to that port from other programms, e.g. your browser? is there a firewall that might block the communication?
television
#206 Posted : Wednesday, October 1, 2014 7:38:44 AM(UTC)
television
I've tried everything. Please contact me in a private message.
macjaeger
#207 Posted : Wednesday, October 1, 2014 9:09:20 AM(UTC)
macjaeger
Will do, but not before tomorrow - i'm a little busy these days...
thanks 1 user thanked macjaeger for this useful post.
television on 10/3/2014(UTC)
Marvin
#208 Posted : Saturday, November 15, 2014 9:55:30 PM(UTC)
Marvin
hi can i make a scheduler and program a live program too, from differen location?
g-mo
#209 Posted : Tuesday, November 18, 2014 10:58:50 AM(UTC)
g-mo
Getting the same thing.
Vmix 14 Windows 8.1 64bit
macjaeger
#210 Posted : Tuesday, November 18, 2014 3:12:48 PM(UTC)
macjaeger
Ok, so i found a little time to analyse vMix 14 in a demo setup on my new laptop. It seems that there have been changes to the api, which will prevent vMixController to connect to vMix (one item was removed that vMixController expected to find). I did a little workaround, please try this version:
http://www.weir3d.de/fil...uler/alpha_07_14_102.zip
This works in my - very limited - tests on my windows 7x64 system.
Sorry for all who have been waiting, my work & my family are my main priorities, and i officially abandonned this project long ago...
g-mo
#211 Posted : Tuesday, November 18, 2014 4:23:32 PM(UTC)
g-mo
No go here on Windows 8. Getting an error box....
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at vMixControler.vMixControler.bn_connect_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.34014 built by: FX45W81RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
vMixControler
Assembly Version: 0.6.30.0
Win32 Version: 0.6.30.0
CodeBase: file:///C:/Users/George/AppData/Local/Temp/Temp1_vMixScheduler_alpha%20(1).zip/vMixScheduler/vMixControler.exe
Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
Win32 Version: 4.0.30319.34239 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Xml
Win32 Version: 4.0.30319.34230 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
g-mo attached the following image(s):
controller error.PNG (10kb) downloaded 2 time(s).
macjaeger
#212 Posted : Tuesday, November 18, 2014 4:31:40 PM(UTC)
macjaeger
Hmm, that's strange. Can you do me a favour? Connect to vMix through your webbrowser and call the API readout, and post it (or send it to me). To do that, you'll have to enter the URL of your vMix webinterface and add "/api" to it, e.g. enter
"http://127.0.0.1:8088/api"
into the adress-bar (that's assuming you have vMix running locally on the same machine and didn't change the default port 8088 of the webinterface).
You should see something like this as a result:
macjaeger attached the following image(s):
g-mo
#213 Posted : Tuesday, November 18, 2014 4:56:10 PM(UTC)
g-mo
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<vmix>
<version>14.0.0.101</version>
<inputs>
<input key="d73337e8-72ed-4370-a928-941bee495d9b" number="1" type="Video" title="Brand New Belongings - Holiday.mp4" state="Completed" position="30116" duration="30116" loop="False" muted="True" volume="100" solo="False" audiobusses="M">Brand New Belongings - Holiday.mp4</input>
<input key="e03f13e1-c459-436d-a00b-94227037db8c" number="2" type="Video" title="Crupi Grands Commercial.mp4" state="Completed" position="30059" duration="30059" loop="False" muted="True" volume="80" solo="False" audiobusses="M">Crupi Grands Commercial.mp4</input>
<input key="55ac7999-0ccb-4372-89ff-e7ff843b76e8" number="3" type="Video" title="Jingle, Featuring Peyton Manning.mp4" state="Completed" position="32090" duration="32090" loop="False" muted="True" volume="100" solo="False" audiobusses="M">Jingle, Featuring Peyton Manning.mp4</input>
<input key="f339bdce-fb1f-40cd-8ae4-f92e421243b5" number="4" type="Video" title="Smart Sprint 30sec.mov" state="Completed" position="0" duration="30948" loop="False" muted="True" volume="92" solo="False" audiobusses="M">Smart Sprint 30sec.mov</input>
<input key="78e4d82b-6ac9-493e-8c4f-725f4cecc673" number="5" type="Video" title="danscomm20142.mov" state="Completed" position="0" duration="60102" loop="False" muted="True" volume="98" solo="False" audiobusses="M">danscomm20142.mov</input>
<input key="b57d6f53-aa4e-41f9-bb91-eafcc327aade" number="6" type="Video" title="Fly Bikes 10-9-14 CC Final-WIREDRIVE_50%.mov" state="Completed" position="0" duration="29905" loop="False" muted="True" volume="100" solo="False" audiobusses="M">Fly Bikes 10-9-14 CC Final-WIREDRIVE_50%.mov</input>
<input key="f13bcd3a-e5a5-4cf4-8401-4741f5e0993e" number="7" type="Xaml" title="GRANDS14.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">
GRANDS14.xaml
<text index="0" name="Text1">100</text>
<text index="1" name="Text2">15-16 Girls</text>
<text index="2" name="Text3">1</text>
<image index="0" name="Object">file:///F:/Grands-Moto-CounterDone.png</image>
</input>
<input key="8553414d-567d-479f-bea1-164be87e22d5" number="8" type="Video" title="Tyler Whitfield HQ.mp4" state="Completed" position="33045" duration="33045" loop="False" muted="True" volume="73" solo="False" audiobusses="M">Tyler Whitfield HQ.mp4</input>
<input key="c7a79ad8-6f05-4426-828a-251d39aa5a69" number="9" type="Video" title="TRANSITION_06.mov" state="Paused" position="0" duration="2936" loop="False" muted="True" volume="38" solo="False" audiobusses="M">TRANSITION_06.mov</input>
<input key="fb21a349-a715-4ce0-966c-7fc7518991d2" number="10" type="Video" title="Women Pro Main 1.mp4" state="Completed" position="279829" duration="279829" loop="False" muted="True" volume="100" solo="False" audiobusses="M">Women Pro Main 1.mp4</input>
<input key="ddfe4e4d-f3e3-46de-b75c-cb616c744c18" number="11" type="Video" title="A Pro Main 1.mp4" state="Paused" position="3621" duration="264107" loop="False" muted="True" volume="100" solo="False" audiobusses="M">A Pro Main 1.mp4</input>
<input key="1b19c7b9-73cf-43e8-9efb-1ed11ab98ea1" number="12" type="Video" title="Redline-Flight-Cranks-30s.mp4" state="Completed" position="32384" duration="32384" loop="False" muted="True" volume="64" solo="False" audiobusses="M">Redline-Flight-Cranks-30s.mp4</input>
<input key="13d34109-577a-4a11-880b-366564a251dd" number="13" type="Video" title="FSNAC1203H_FS456.mp4" state="Completed" position="16161" duration="16161" loop="False" muted="True" volume="100" solo="False" audiobusses="M">FSNAC1203H_FS456.mp4</input>
<input key="3d8b5108-b523-4ee1-9021-22c283de9f20" number="14" type="Video" title="Promax.mp4" state="Completed" position="30037" duration="30037" loop="False" muted="True" volume="100" solo="False" audiobusses="M">Promax.mp4</input>
<input key="489ed9f5-8afc-44e7-b585-eafbec51d126" number="15" type="Video" title="BOX V3 GRADED.mp4" state="Completed" position="30037" duration="30037" loop="False" muted="False" volume="100" solo="False" audiobusses="M">BOX V3 GRADED.mp4</input>
<input key="fd9c6423-bff9-47f0-8bf0-90457fdeda36" number="16" type="Video" title="Ohio Dreams.mp4" state="Paused" position="9243" duration="30080" loop="False" muted="True" volume="100" solo="False" audiobusses="M">Ohio Dreams.mp4</input>
<input key="33f32d35-80c5-4019-92d7-03b4759daea1" number="17" type="Video" title="VSN-Life in V.360°.mp4" state="Completed" position="68661" duration="68661" loop="False" muted="True" volume="100" solo="False" audiobusses="M">VSN-Life in V.360°.mp4</input>
<input key="24e48c6f-f35b-495f-b0b9-0c6ec37ae344" number="18" type="Video" title="VSN-V.360°.mp4" state="Completed" position="41006" duration="41006" loop="False" muted="True" volume="78" solo="False" audiobusses="M">VSN-V.360°.mp4</input>
<input key="3ca2088e-54ac-4e18-83cc-bb9d3ffd6fe9" number="19" type="Xaml" title="RSS.xaml" state="Completed" position="1617" duration="30000" loop="False" selectedIndex="0">
RSS.xaml
<text index="0" name="AnimatedTicker">
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Nunc non hendrerit lectus. Duis bibendum posuere elit. Aenean sit amet lacus vel leo sollicitudin rhoncus. Donec magna neque, congue at sodales sit amet, venenatis quis felis. Curabitur lacinia semper justo, vitae lobortis augue placerat ac. Donec turpis nisi, hendrerit ut iaculis a, sodales varius libero. Mauris neque arcu, lacinia nec aliquam id, cursus et ante. Fusce porta convallis rhoncus. Aliquam erat volutpat. Nulla facilisi. Lorem ipsum dolor sit amet, consectetur adipiscing elit. Sed a augue velit, et cursus quam. Cras massa mauris, dictum quis aliquet ut, eleifend ut risus.
</text>
<text index="1" name="BackgroundColor">
Use the colorpicker above to change the color of the ticker
</text>
<text index="2" name="LogoOpacityPercent">1</text>
</input>
<input key="2887145a-4a68-47c6-a029-57c2db690b3e" number="20" type="VideoDelay" title="Delay - Output" state="Paused" position="19953" duration="19987" loop="False">Delay - Output</input>
<input key="a24180a0-8117-46a7-9f52-2087c27fc86d" number="21" type="Xaml" title="TickerHD3.xaml" state="Paused" position="0" duration="120000" loop="False" selectedIndex="0">
TickerHD3.xaml
</text>
</input>
</inputs>
<overlays>
<overlay number="1"/>
<overlay number="2"/>
<overlay number="3"/>
<overlay number="4"/>
<overlay number="5"/>
<overlay number="6"/>
</overlays>
<preview>19</preview>
<active>15</active>
<fadeToBlack>False</fadeToBlack>
<transitions>
<transition number="1" effect="Fade" duration="500"/>
<transition number="2" effect="Wipe" duration="500"/>
<transition number="3" effect="Fade" duration="500"/>
<transition number="4" effect="Fade" duration="1000"/>
</transitions>
<recording>False</recording>
<external>False</external>
<streaming>False</streaming>
<playList>False</playList>
<multiCorder>False</multiCorder>
<audio>
<master volume="100" muted="False" headphonesVolume="8"/>
</audio>
</vmix>
macjaeger
#214 Posted : Tuesday, November 18, 2014 4:59:00 PM(UTC)
macjaeger
I am going to look deeper into it, but the first thing i noticed is the different version of vMix. I've been testing with the slightly newer version 14.0.0.102, while you are running 14.0.0.101. I don't know if that's the reason, but it can't hurt to update your vMix version to the latest while i'm examining your xml file closer.
g-mo
#215 Posted : Tuesday, November 18, 2014 5:18:55 PM(UTC)
g-mo
Just updated. Same thing.
Also need to note that Scheduler is not pushing anything to the Controller.
When push to Schedule is clicked I get the Success! dialog box but nothing is generated in the Controller. Reload Schedule in the controller doesn't populate anything.
macjaeger
#216 Posted : Tuesday, November 18, 2014 5:19:52 PM(UTC)
macjaeger
I build a little debug-version that should help us get closer to the source of the problem. Please download the attached file and decompress it, it contains only vMixControlerDebug.exe, you have to put it in the same place where you put the rest of vMixControler files.
After you run it, it should print a more helpful message box, which i ask you to screenshot for me.
File Attachment(s):
vMixControlerDebug.zip (18kb) downloaded 54 time(s).
macjaeger
#217 Posted : Tuesday, November 18, 2014 5:21:53 PM(UTC)
macjaeger
Hmm, that's probably another unrelated problem. Both programms communicate indirectly through a common schedule file, maybe there are some new restrictions in win 8 that i'm not aware of... we'll look into this a little later, but first we need to get vMixController running and connecting :-)
macjaeger
#218 Posted : Tuesday, November 18, 2014 5:28:51 PM(UTC)
macjaeger
There is a special folder that both programms use to read/write schedule data; it should be located at "c:\user\all users\vMixScheduler" . Please verify if this folder is there, and if it contains some files. It should at least contain "Settings.xml" and "vMixSchule.xml", and probably a number of logfiles as well. But chances are that windows again changed their folder structure to give us programmers a hard time... :-/
g-mo
#219 Posted : Tuesday, November 18, 2014 6:19:24 PM(UTC)
g-mo
mscorlib
vMixControler
Assembly Version: 0.7.14.102
Win32 Version: 0.7.14.102
CodeBase: file:///C:/Users/George/AppData/Local/Temp/Temp1_vMixControlerDebug.zip/vMixControlerDebug.exe
System.Drawing
System
enabled.
For example:
<configuration>
</configuration>
macjaeger
#220 Posted : Tuesday, November 18, 2014 6:29:59 PM(UTC)
macjaeger
You still got this from the debug-version of vMixController?!
That's very peculiar! Do you get this right when you start it, or only after you press "connect"? The debug-info given in this text comes from the system itself, not from my programm - it claims that there is an "unhandled exception" when you press the button "bn_connect", which is the connect button, but i have an exception handler in place that should catch any exceptions in this part of the programm...
The only other thing i can think of now is a misconfiguration or missing part of .net, which is used as a basis for vMixController.
Did you find the folder i mentioned before? Are there any logfiles in it?
Guest (19)
