Joined: 1/13/2010(UTC) Posts: 5,363  Location: Gold Coast, Australia Was thanked: 4775 time(s) in 1640 post(s)
29.0.0.34
Initial release
* Fixed Input Settings zoom slider cut off on General tab
 6 users thanked admin for this useful post.
29.0.0.35
* Fixed vMix AVI playback quality issue when using LQ quality setting.
 5 users thanked admin for this useful post.
29.0.0.36
* Added an error when recording > 6 channels of audio to MP4 in MultiCorder * Fixed transition issue when using "Match Replay Speed" option for event transitions
29.0.0.37
* Zoom now requires logging in to an account when Joining a meeting * Added Original Sound and Echo Cancellation option * Fixed audio meter not updating when a source is Live Paused * Fixed List input still showing video of removed item if all other items in list are disabled * List input now works correctly when all items removed and/or disabled * Fixed pause button not showing correct status for Live Pause inputs after transition * Fixed OMT outputs enabled toggle not being saved/restored in Preset
 7 users thanked admin for this useful post.
29.0.0.38
* Fixed layers not playing when set to auto play on top of a live capture source
29.0.0.39
* Fix for saving a List in a preset that previously had all items removed from it.
29.0.0.40
* GT Designer PSD import updated to preserve original numbering of elements where possible. * vMix Video Codec updated with a workaround for a rare bug in Adobe Premiere that cause some files to fail to import. * Fix for Replay Event Text editor not accepting edits in some situations, mainly due to auto-matching existing items in dropdown list.
29.0.0.41
* Fixed streaming error when using Use Hardware Encoder on the latest NVIDIA drivers 590 and higher. * Fix for play/pause button icon underneath Replay A and B inputs not matching current state in some situations.
29.0.0.44
* Fixed NVIDIA GPU issue when streaming AV1 to YouTube for greater than 2 hours 45 minutes * Added YouTube Live RTMPS streaming destination option * Statistics Encoders tab improvements: 1. Will now show correct Software encoder status when Recording/MultiCorder falls back to software when hardware encoder is not available. 2. List of encoders is now sorted correctly 3. MultiCorder sources now displayed correctly 4. A counter of total hardware encoders has been added * Recording/MultiCorder will now allow recording > 6 channels of audio to WAV when using MP4. The WAV option will need to be selected which will contain all channels, while the first 6 channels will be included with MP4. * Tooltip improvements for Overlay and Audio Buses * Fix for Outputs in MultiCorder not getting reconfigured/restarted correctly when output settings changed. * Fix issue where changing multiple Replay sources back to None does not work * Fixed titles in Replay not updating when changing original source input name * Fixed & symbol not displaying in input headers correctly * Added workaround for persistent tooltip on audio meters due to bug in Windows 11
 17 users thanked admin for this useful post.
doggy on 1/7/2026(UTC), Peter Berglund on 1/7/2026(UTC), eduardocfs on 1/7/2026(UTC), raugert on 1/7/2026(UTC), jet on 1/8/2026(UTC), AngusFindlay on 1/8/2026(UTC), Reinaldo on 1/8/2026(UTC), sinc747 on 1/8/2026(UTC), pm on 1/8/2026(UTC), monamiga on 1/8/2026(UTC), Soundfloss on 1/8/2026(UTC), avsoundguy on 1/9/2026(UTC), tsioukas on 1/10/2026(UTC), djmoll on 1/10/2026(UTC), kross on 1/12/2026(UTC), Santhosh Joseph on 3/29/2026(UTC), stigaard on 4/11/2026(UTC)
29.0.0.45
* Fixed error when starting stream or recording when Telestrator is enabled in some rare cases * Fixed not being able to reconnect to a Zoom call in some situations
29.0.0.46
* Fix for high frame rate issue with SRT inputs * Fix for inaccurate audio delay when using EmbeddedAllChannels * Fix for BusXAudio shortcuts not working for value of M * Improved performance of Data Sources table view when source contains large number of columns
 10 users thanked admin for this useful post.
29.0.0.47
* Fix for issue in GT Designer where typing in a number into some dropdown boxes may not save correctly. * Fix for LUT showing incorrect results on some NVIDIA drivers due to YUV/RGB range handling * Fix for high frame rate issue with SRT inputs (prior fix did not work correctly) * Fix for Zoom Manager frame rate counter showing zero when actual frame rate was 60.
 9 users thanked admin for this useful post.
29.0.0.48
* Network performance improvement when receiving multiple OMT sources on a > 1Gbps network. * Added initial support for Windows 11 Smart App Control, to allow vMix to run when enabled.
29.0.0.49
* Updated SRT version to 1.5.6 * vMix now re-applies Mute to Zoom's system audio after joining a meeting, as Zoom may unmute audio on some systems unexpectedly.
29.0.0.50
* Fixed issue where vMix Update Launch would start vMix in a way where new browser input might fail * Fix for MultiCorder starting recordings for disabled capture inputs when those inputs would report a video format change * Fix for error where MultiCorder source was in the middle of changing formats when recording begins
