#1 Posted : Monday, October 27, 2025 2:37:26 PM(UTC)
Was thanked: 4801 time(s) in 1648 post(s)
29.0.0.34
Initial release
* Fixed Input Settings zoom slider cut off on General tab
thanks 6 users thanked admin for this useful post.
jet on 10/27/2025(UTC), QuiapoChurch on 10/27/2025(UTC), eduardocfs on 10/27/2025(UTC), vijay6672 on 10/30/2025(UTC), sinc747 on 4/2/2026(UTC), RUN TV on 7/12/2026(UTC)
#2 Posted : Tuesday, October 28, 2025 2:49:21 PM(UTC)
29.0.0.35
* Fixed vMix AVI playback quality issue when using LQ quality setting.
thanks 5 users thanked admin for this useful post.
QuiapoChurch on 10/28/2025(UTC), jet on 10/28/2025(UTC), eduardocfs on 11/16/2025(UTC), sinc747 on 4/2/2026(UTC), stigaard on 4/11/2026(UTC)
#3 Posted : Sunday, November 2, 2025 9:51:47 PM(UTC)
29.0.0.36
* Added an error when recording > 6 channels of audio to MP4 in MultiCorder
* Fixed transition issue when using "Match Replay Speed" option for event transitions
QuiapoChurch on 11/3/2025(UTC), monamiga on 11/3/2025(UTC), jet on 11/5/2025(UTC), eduardocfs on 11/16/2025(UTC), sinc747 on 4/2/2026(UTC), stigaard on 4/11/2026(UTC)
#4 Posted : Friday, November 14, 2025 3:50:52 PM(UTC)
29.0.0.37
* Zoom now requires logging in to an account when Joining a meeting
* Added Original Sound and Echo Cancellation option
* Fixed audio meter not updating when a source is Live Paused
* Fixed List input still showing video of removed item if all other items in list are disabled
* List input now works correctly when all items removed and/or disabled
* Fixed pause button not showing correct status for Live Pause inputs after transition
* Fixed OMT outputs enabled toggle not being saved/restored in Preset
thanks 7 users thanked admin for this useful post.
doggy on 11/14/2025(UTC), monamiga on 11/15/2025(UTC), eduardocfs on 11/16/2025(UTC), jet on 11/17/2025(UTC), eee8bit on 11/21/2025(UTC), sinc747 on 4/2/2026(UTC), stigaard on 4/11/2026(UTC)
#5 Posted : Sunday, November 16, 2025 12:06:07 PM(UTC)
29.0.0.38
* Fixed layers not playing when set to auto play on top of a live capture source
eduardocfs on 11/16/2025(UTC), jet on 11/17/2025(UTC), monamiga on 11/17/2025(UTC), raugert on 11/18/2025(UTC), sinc747 on 4/2/2026(UTC), stigaard on 4/11/2026(UTC)
#6 Posted : Wednesday, November 19, 2025 11:12:53 AM(UTC)
29.0.0.39
* Fix for saving a List in a preset that previously had all items removed from it.
QuiapoChurch on 11/19/2025(UTC), monamiga on 11/20/2025(UTC), eduardocfs on 11/22/2025(UTC), jet on 11/23/2025(UTC), sinc747 on 4/2/2026(UTC), stigaard on 4/11/2026(UTC)
#7 Posted : Sunday, November 23, 2025 8:03:22 PM(UTC)
29.0.0.40
* GT Designer PSD import updated to preserve original numbering of elements where possible.
* vMix Video Codec updated with a workaround for a rare bug in Adobe Premiere that cause some files to fail to import.
* Fix for Replay Event Text editor not accepting edits in some situations, mainly due to auto-matching existing items in dropdown list.
jet on 11/23/2025(UTC), eduardocfs on 11/24/2025(UTC), QuiapoChurch on 11/24/2025(UTC), Soundfloss on 11/25/2025(UTC), monamiga on 11/25/2025(UTC), sinc747 on 4/2/2026(UTC), stigaard on 4/11/2026(UTC)
#8 Posted : Friday, December 5, 2025 1:49:16 PM(UTC)
29.0.0.41
* Fixed streaming error when using Use Hardware Encoder on the latest NVIDIA drivers 590 and higher.
* Fix for play/pause button icon underneath Replay A and B inputs not matching current state in some situations.
eduardocfs on 12/6/2025(UTC), pm on 12/6/2025(UTC), monamiga on 12/6/2025(UTC), Soundfloss on 12/12/2025(UTC), jet on 12/15/2025(UTC), sinc747 on 1/1/2026(UTC), stigaard on 4/11/2026(UTC)
#9 Posted : Wednesday, January 7, 2026 4:28:57 PM(UTC)
29.0.0.44
* Fixed NVIDIA GPU issue when streaming AV1 to YouTube for greater than 2 hours 45 minutes
* Added YouTube Live RTMPS streaming destination option
* Statistics Encoders tab improvements:
1. Will now show correct Software encoder status when Recording/MultiCorder falls back to software when hardware encoder is not available.
2. List of encoders is now sorted correctly
3. MultiCorder sources now displayed correctly
4. A counter of total hardware encoders has been added
* Recording/MultiCorder will now allow recording > 6 channels of audio to WAV when using MP4.
The WAV option will need to be selected which will contain all channels, while the first 6 channels will be included with MP4.
* Tooltip improvements for Overlay and Audio Buses
* Fix for Outputs in MultiCorder not getting reconfigured/restarted correctly when output settings changed.
* Fix issue where changing multiple Replay sources back to None does not work
* Fixed titles in Replay not updating when changing original source input name
* Fixed & symbol not displaying in input headers correctly
* Added workaround for persistent tooltip on audio meters due to bug in Windows 11
thanks 17 users thanked admin for this useful post.
doggy on 1/7/2026(UTC), Peter Berglund on 1/7/2026(UTC), eduardocfs on 1/7/2026(UTC), raugert on 1/7/2026(UTC), jet on 1/8/2026(UTC), AngusFindlay on 1/8/2026(UTC), Reinaldo on 1/8/2026(UTC), sinc747 on 1/8/2026(UTC), pm on 1/8/2026(UTC), monamiga on 1/8/2026(UTC), Soundfloss on 1/8/2026(UTC), avsoundguy on 1/9/2026(UTC), tsioukas on 1/10/2026(UTC), djmoll on 1/10/2026(UTC), kross on 1/12/2026(UTC), Santhosh Joseph on 3/29/2026(UTC), stigaard on 4/11/2026(UTC)
#10 Posted : Tuesday, January 20, 2026 2:43:06 PM(UTC)
29.0.0.45
* Fixed error when starting stream or recording when Telestrator is enabled in some rare cases
* Fixed not being able to reconnect to a Zoom call in some situations
eduardocfs on 1/20/2026(UTC), monamiga on 1/20/2026(UTC), tsioukas on 1/21/2026(UTC), jet on 1/21/2026(UTC), sinc747 on 1/24/2026(UTC), stigaard on 4/11/2026(UTC)
#11 Posted : Monday, February 2, 2026 12:19:31 PM(UTC)
29.0.0.46
* Fix for high frame rate issue with SRT inputs
* Fix for inaccurate audio delay when using EmbeddedAllChannels
* Fix for BusXAudio shortcuts not working for value of M
* Improved performance of Data Sources table view when source contains large number of columns
thanks 10 users thanked admin for this useful post.
jet on 2/2/2026(UTC), eduardocfs on 2/3/2026(UTC), monamiga on 2/3/2026(UTC), Peter1000 on 2/3/2026(UTC), sinc747 on 2/4/2026(UTC), goyco2003 on 2/9/2026(UTC), raugert on 2/10/2026(UTC), RichDanby on 2/11/2026(UTC), Santhosh Joseph on 3/29/2026(UTC), stigaard on 4/11/2026(UTC)
#12 Posted : Wednesday, April 1, 2026 2:59:11 PM(UTC)
29.0.0.47
* Fix for issue in GT Designer where typing in a number into some dropdown boxes may not save correctly.
* Fix for LUT showing incorrect results on some NVIDIA drivers due to YUV/RGB range handling
* Fix for high frame rate issue with SRT inputs (prior fix did not work correctly)
* Fix for Zoom Manager frame rate counter showing zero when actual frame rate was 60.
thanks 9 users thanked admin for this useful post.
jet on 4/1/2026(UTC), Chircanu on 4/1/2026(UTC), sinc747 on 4/2/2026(UTC), AngusFindlay on 4/2/2026(UTC), QuiapoChurch on 4/2/2026(UTC), monamiga on 4/2/2026(UTC), eduardocfs on 4/7/2026(UTC), stigaard on 4/11/2026(UTC), Alain Lahaye on 5/5/2026(UTC)
#13 Posted : Tuesday, June 2, 2026 5:42:25 PM(UTC)
29.0.0.48
* Network performance improvement when receiving multiple OMT sources on a > 1Gbps network.
* Added initial support for Windows 11 Smart App Control, to allow vMix to run when enabled.
jet on 6/2/2026(UTC), eduardocfs on 6/2/2026(UTC), doggy on 6/2/2026(UTC), AngusFindlay on 6/3/2026(UTC), monamiga on 6/3/2026(UTC), QuiapoChurch on 6/3/2026(UTC), turbo400 on 6/4/2026(UTC)
#14 Posted : Saturday, August 15, 2026 5:45:27 PM(UTC)
29.0.0.49
* Updated SRT version to 1.5.6
* vMix now re-applies Mute to Zoom's system audio after joining a meeting, as Zoom may unmute audio on some systems unexpectedly.
RichDanby on 8/15/2026(UTC), eduardocfs on 8/16/2026(UTC), jet on 8/16/2026(UTC), monamiga on 8/16/2026(UTC), QuiapoChurch on 8/17/2026(UTC)
#15 Posted : Thursday, November 12, 2026 4:19:03 PM(UTC)
29.0.0.50
* Fixed issue where vMix Update Launch would start vMix in a way where new browser input might fail
* Fix for MultiCorder starting recordings for disabled capture inputs when those inputs would report a video format change
* Fix for error where MultiCorder source was in the middle of changing formats when recording begins
thanks 4 users thanked admin for this useful post.
jet on 11/12/2026(UTC), QuiapoChurch on 11/12/2026(UTC), sinc747 on 11/13/2026(UTC), monamiga on 11/16/2026(UTC)
