jorisdv
#1 Posted : Wednesday, November 4, 2026 6:39:36 PM(UTC)
jorisdv
Hi
Running vMix 30 preview 30.0.0.22.
Steps to reproduce:
1. Create an input, e.g. color bars
2. Enable Output 1 and tick the 8-10 bit conversion box
3. Enable External
To verify what is outputted, either attach a SDI monitor to the Output or create a loop back into a second SDI Input (did both)
1. Use a short cable to link the SDI Output to an SDI Input
2. Add a Camera Input that refers to that SDI Input
I noticed a shift of the image, like 2/3 of the image is show left, the 1/3 at the start is shown at the end.
See the attached images for reference.
When disabling the 8-10bit conversion the issue is no longer.
Tested with BMD Decklink Duo, Decklink IP HD and Decklink IP 100G.
Input Color bars
Output Color bars 10-bit
Output Color bars 8-bit
Input Video
Output Video 10-bit
#2 Posted : Wednesday, November 4, 2026 7:40:56 PM(UTC)
Was thanked: 4756 time(s) in 1632 post(s)
Thanks for the report, we will get this fixed in the next update.
#3 Posted : Wednesday, November 4, 2026 11:08:50 PM(UTC)
This should now be fixed:
https://forums.vmix.com/...view-Released#post122941
Let me know if you still see the image looking incorrect after updating.
jorisdv
#4 Posted : Wednesday, November 4, 2026 11:29:37 PM(UTC)
jorisdv
I can confirm the update resolves the issue.
Thank you for the swift update!
