jkmakela
#1 Posted : Friday, September 12, 2014 2:18:24 PM(UTC)
jkmakela
Rank:: Advanced Member
Hello, some why I do not find simple way to put image and video files in a playlist and play them in the loop mode. This is basic situation in live events when there is brake in the event - we are supposed to play commercials and sponsor logos until the show continues. Last time I had to render all logos and videos to be an one video file with FCP.
How this is supposed to be done in correct and simple way?
redbeard
#2 Posted : Tuesday, September 16, 2014 5:17:28 PM(UTC)
redbeard
Can't you just build the list in a playlist and tick the loop box?
jkmakela
#3 Posted : Friday, September 19, 2014 11:23:16 AM(UTC)
jkmakela
playlist does not support images and videos at the same time. If I have understood correctly it has to be separe playlist for videos and separate list for images (slideshow). But we want something like this:
- logo.jpg (5seonds)
- logo2.jpg (5seonds)
- video1.mov.
- video2.mov
- timetable.jpg (10 seonds)
- video3.mov
- vide4.mov
and loop again
#4 Posted : Saturday, September 20, 2014 9:07:20 AM(UTC)
@ jkmakela
Have you tried the vMixScheduler?
http://forums.vmix.com.a...t.aspx?g=posts&t=999
It doesn't loop but you may find a way to work around that.
Kelvin
#5 Posted : Saturday, September 20, 2014 9:54:00 AM(UTC)
Kelvin
Can you pull the photos into a video editor and render out the 5 or 10 second clips as .mov files? Then everything would be video files that would easily work in the playlist.
LG
#6 Posted : Sunday, September 21, 2014 8:35:57 AM(UTC)
LG
IceStream wrote:
@ jkmakela
there are no updates are there that provide looking..
jkmakela
#7 Posted : Thursday, September 25, 2014 4:49:51 PM(UTC)
jkmakela
ok, it seems that there is no simple way to do the looping list with video and image files. I would put this issue into the whish list. Vmix can do so many other things that this should not be problem for Martin. There is no time in events to render separate video files from images in external editor, in order to use only video list in vmix. Basic situation: you have some logos and videos to loop in live events.
