Importing Your Mobile Camera Iphone Into vMix!
Can you help me, Importing Your Mobile Camera Iphone Into vMix!
Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 17 time(s) in 16 post(s)
As I see it there's two ways of doing it: you can either use a lightning cable to HDMI adapter and use a capture card or use an Apple TV and capture that via HDMI. Both should be fairly reliable. Especially the first option. You can then open the camera app on your phone.
Alternatively you can do a Skype call into vmix or see if you can find a virtual camera for iOS that works (I havent been able to find one that works well yet, but that might be our wifi)
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
You could try the program Reflector 2 (http://www.airsquirrels.com/reflector/features/win/) Works with windows or Mac, this is the windows link. It lets you send the video and audio via "AirPlay" and you can mirror the screen to the PC and Capture with vMix.
Normally i use the HDMI Adapter into an Intensty Pro 4K, but if I have more than 1 device simultaneously I use reflector.
Cpilcher
I do not want to capture the screen Mobile phone. Do you know use Broadcast me?
Joined: 3/17/2013(UTC) Posts: 235  Location: Indiana Thanks: 95 times Was thanked: 30 time(s) in 28 post(s)
tct40 wrote:I do not want to capture the screen Mobile phone. Do you know use Broadcast me? tct40, Screen capture from a second laptop into vMix really does work very well with Skype. I've done that many, many times. Problem may be with wifi over a large area. Wifi is just too unstable. When doing something like that outdoors I used the phone data provider for Skype caller and captured the Skype call on the second computer. ~George
tct40 wrote:Can you help me, Importing Your Mobile Camera Iphone Into vMix! I'm assuming vMix can accept a RTMP source? There'a a few apps that encodes and sends video as RTMP. Example: "Broadcast Me" https://itunes.apple.com...?mt=8&ign-mpt=uo%3D4
Joined: 8/18/2025(UTC) Posts: 12  Location: France Thanks: 15 times Was thanked: 8 time(s) in 8 post(s)
Old thread, but it still shows up in searches, so here is a 2026 update for anyone landing here. The options mentioned above (HDMI adapter + capture card, AirPlay mirroring, Skype) still work, but there are simpler ways now: vMix Call: open the guest link in Safari on the iPhone, no app needed. Good for remote guests, but you are limited by the browser camera controls and the call quality settings. OMT: since vMix 28, OMT (Open Media Transport) is built into vMix as a native input, the same way NDI is. On a local network an iPhone can send camera video and audio as an OMT source, and it simply appears in vMix as a new input, no capture card, no cable, low latency. Full disclosure: I’m the developer of OMTake, an iOS app that does exactly that (phone camera as an OMT source for vMix, with control over framerate, focus, exposure, white balance, stabilization). Details, feedback and feature requests are in this thread: https://forums.vmix.com/...-OMTake-Feature-RequestsHappy to answer questions here about getting an iPhone into vMix, whatever method you choose.
Joined: 11/27/2023(UTC) Posts: 134  Thanks: 10 times Was thanked: 9 time(s) in 9 post(s)
